Is there a limit on the number of events that can trigger from a device change?
    Hi,
    I am trying to debug a routine that I am writing. I have the following set up:
    IF Motion Sensor has value set to Motion THEN set virtualDevice to ON
    IF virtualDevice has value set to ON
    THEN Start Timer
    IF virtualDevice has value set to ON AND IF Time is after 10 PM
    THEN set Light to ON
    IF virtualDevice has value set to ON AND IF Time is 10 M before sunrise
    For some reason the later two events never seems to fire, which leads me to my question. Is there a limit on the number of events that can trigger from a single action?
    Lou
    No.
    The reason your events do not trigger is more likely to be because HS is evaluating the triggers and conditions differently than you expect.
    The last event will not trigger unless the virtual device is set to On at EXACTLY 10 minutes before sunrise, which is probably not what you intend.
    I think what you want is something like:
    If the time is 10 min before sunrise
    And If the virtual device is On
    Then turn on light
    The next to last event should run if the virtual device is set to on between 10 PM and midnight. Is that what you want to happen?
