Auto Update - How do i turn off?
    With the last two updates my system has hung until I rebooted. How do I turn the auto update?
    Thanks in advance
    There is no auto update in HS3/4. Are you referring to auto update of Windows? If so, some people report that defining your internet connection as a metered connection helps preventing auto updates.
      If you are wanting HS to stop checking for updates on startup then uncheck the setting in Setup/General/Other Settings/Check for Update at Startup.
      Scripts =
      Various
        I was referring to HS4
        I have unselected Setup/General/Other Settings/Check for Update at Startup.
        For some reason the past two HS4 updates have started after a power outage and then HS4 sat waiting for confirmation. This leaves HS4 in an unstable state and therefore is not actually running. That, obviously causes problems with timed events.
        Will force a crash and see if that resolves the issue. As well, I now know my battery backup needs to be replaced with a larger capacity.
        Thanks!
