How to manage a 4 button Vitrum with roller shutter - problem
    #16
    Originally posted by atiretta View Post
    Yes, timestamp change everytime when I press a button and flag is unchecked.
    I'm out of ideas. If pressing the same button in Homseer (UP or DOWN) a second time--which should be sending the 99 value to the device a second time--doesn't cause it to pause then it may be that Homeseer simply doesn't fully support the device.
    Hopefully someone else will jump in with other thoughts.
    -Wade
      #17
      I can sai that:
      0 is alwais Down in both buttons
      99 or 255 is always Up in both button BUT if you click on 255 button, the value is set to 99 so I think that 255 is not used.
      Maybe just 0 and 99.
        #18
        Your post #6 shows 0/Down, 99/Up, 255/Pause. For a dimmer switch, 255 typically sets the dimmer to Last dim level. Not sure whether that's relevant here.
        edited
        -Wade
          #19
          Maybe I've to change Device Type String (now is Switch Multilevel) with some other parameter like "button"?
            #20
            Originally posted by Wade View Post
            I just noticed the value/status pairs are different in your post #5 than in post #12. Previously it was 0/Down, 99/Up, 255/Pause. Now Pause seems to be value 0 and both Down and Up are 99 but on different devices. Any idea what changed?
            Yes, I've verify that 255 is not used and labels are just labels... ;-)
              #21
              Do you want to remotely connect to my screen with AnyDesk or Meet or other program?
              Maybe, if we see and talk, is easier for you ;-)
                #22
                I'm afraid I've offered all my ideas already. Maybe someone with more knowledge will join the conversation.
                -Wade
                  #23
                  Ok, thanks a lot !!!
