Instruction Sheet For X10 Motion Sensors
This topic is closed.
  • Instruction Sheet For X10 Motion Sensors
    Set-Up and Operating Instructions for MS13A Indoor Motion Detector
    House Unit one number higher than the Unit Code of the module that turns on when motion is detected. I.E. if the MS13A turns on A1 when it detects motion, it will turn on A2 when it gets dark and turn it off when it gets light.
    Options:
    To change the Unit Code that the MS13A transmits: Press and hold the Unit/Off button (under the battery compartment lid) the red LED flashes first and then blinks the current setting. Release and immediately press the button the desired number of times for the Unit Code you want to set and hold the button on the last press. 3 seconds after the last press (while holding the button) the red LED blinks back the number of times for the code you set. Release the button.
    To change the House Code that the MS13A transmits: Press and hold the House/On button (under the battery compartment lid) the red LED flashes first and then blinks the current setting (once for A, twice for B, etc.). Release and immediately press the button the desired number of times for the House Code you want to set (once for A, twice for B, etc.) and hold the button on the last press. 3 seconds after the last press (while holding the button) the red LED blinks back the number of times for the code you set. Release the button.
    To set whether you want the MS13A to transmit EVERY time it sees motion or only at night: Press the Unit/Off button once. The red LED flashes. Then press and hold the House/On Unit/Off button once. The red LED flashes. Then press and hold the House/On button. The green LED turns on. 3 seconds later the MS13A reports its dusk/dawn setting. Release and immediately press the House/On button once for operation at all times, twice for operation only at night or three times to report dusk/dawn and motion at all times. Hold the button for 3 seconds on your last press. The red LED then reports the setting with one two or three blinks.
    To change the delay after motion is detected before an OFF code is transmitted: Press the House/On button once. The red LED flashes. Press and hold the Unit/Off button. The green LED turns on. 3 seconds later the red LED reports its delay setting as follows:
    1 blink for 1 minute.
    2 blinks for 2 minutes.
    3 blinks for 4 minutes.
    4 blinks for 8 minutes.
    5 blinks for 16 minutes.
    6 blinks for 32 minutes.
    7 blinks for 64 minutes.
    8 blinks for 128 minutes.
    9 blinks for 256 minutes.
    To change this, Press the House/On button once. The red LED flashes. Press and hold the Unit/Off button. The green LED turns on. 3 seconds later the red LED reports its delay setting. Release and immediately press the Unit/Off button the number of times for the delay you want. Hold the button pressed for 3 seconds on the last press. The red LED then reports the setting with the appropriate number of blinks as above. Release the button.
    NOTES:
    After replacing batteries unless the unit is fitted with an eprom it will revert to it's default settings and you need to wait 30 seconds before the MS13A will see any motion. After a transmission, you need to wait 10 seconds before the MS13A will see you.
    The default House and Unit Code transmitted when motion is detected is A 1 ON.
    The default for motion detection is detect at all times (day and night).
    The default time out after which (default) A 1-OFF is sent is 1 minute.
    The default House and Unit Code transmitted when dusk/dawn is sensed is A 2-ON at dusk, A 2 -OFF at dawn.
    Last edited by Gogs; March 8th, 2013, 07:27 PM. Reason: Important instruction missing
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
