Linux Static USB port configuration for Homeseer 3
  • Linux Static USB port configuration for Homeseer 3
    Suggested fix is:
    Write a simple udev-rule which will assign symlink /dev/whatever to right device by its VID & PID.
    1 - Find out what is on ttyUSB
    dmesg | grep ttyUSB
    2 - list all attributes of the device and pick out a unique identifier set, eg idVendor + idProduct (and if necessary SerialNumber if you have more than one device with the same idVendor and idProduct).
    udevadm info --name=/dev/ttyUSB1 --attribute-walk
    3 - Create a file /etc/udev/rules.d/99-usb-serial.rules with something like this line in it:
    SUBSYSTEM=="tty", ATTRS{idVendor}=="1234", ATTRS{idProduct}=="5678", SYMLINK+="your_device_name"
    4 - Load the new rule:
    sudo udevadm trigger
    5 - Verify what happened:
    ls -l /dev/your_device_name
    will show what ttyUSB number the symlink went to. If it's /dev/ttyUSB1, then verify who owns that and to which group it belongs:
    ls -l /dev/ttyUSB1
    Then just for the fun of it:
    udevadm test -a -p $(udevadm info -q path -n /dev/your_device_name)
    - Pete
    Auto mator
    HS4 pro - 4.0.3.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
