Contacting HomeSeer This Week
See more
See less
How to Set Up User-Level Access in HomeSeer
This is a sticky topic.
  • How to Set Up User-Level Access in HomeSeer
    Rich enhanced user level access a few releases ago with very little fanfare. If you didn't read the release notes, you probably weren't aware of this. Here's a quick little video showing up some of these cool new tweaks:
    Learn About HomeSeer
  • #2
    Thanks for posting this Mark. Will z-tool+ be updated at some point to work with local logins enabled? I would like to enable this in the near future as my boys' computer knowledge will likely exceed mine in the near future, but don't want to lose the z-tool functionality. [emoji3]
    Al
    HS 3.0.0.548: 1990 Devices 1172 Events
    Z-Wave 3.0.1.262: 126 Nodes on one Z-Net
    • #3
      Al
      What do you imagine your kids would do with Z-Tool+? curious...
      • #4
        Hi Mark, I don't want them using ztool +, I want to use it, but my understanding is that it doesn't work if local logins is enabled. I want to give my boys access to certain devices in HS and restrict access to others so want to enable local logins.
        Al
        • #5
          Al
          I see what you mean. When you need to add devices to your network with Z-Tool+, just untick the setting. After you're done, tick that setting again. I'm guessing you're not adding/deleting devices all that frequently, right? The alternative would be to require a login in ZTool+, which would make everyone always have to log in manually to use it. Since most people don't have the need for user-level access, that would be complicating things for the majority to make life easier for the few.
          • #6
            Seems like that is defeating the purpose of z-tool. I'd have to use the web interface first so that I don't have to use the web interface for the zwave plugin [emoji1]. How about an option in z-tool that allows you to configure if you want it to prompt you for login credentials?
            Cheers
            Al
            PS I could argue that most people should be running with local logins enabled as security by obscurity is really not good enough these days... [emoji12]
            • #7
              Cheers
              Al
              If everybody enabled local logins, this would be a no-brainer and we'd simply force a login with Z-Tool+. However, very few opt for that and for good reason. If a thief is logging into your system locally, he's probably already in your house, in which case... you've got bigger problems than unauthorized HS access!
              • #8
                User access not working in HS3Touch
                Mark
                I have edited many many devices to create a much smaller list of devices for my wife to access. When I log in as her from the Web UI, either locally or externally via my own domain the user access settings are honoured correctly.
                When I log in using her account from HS3Touch externally using my own domain the user controls are ignored and she can still see all the devices that I removed access for. Haven't tried internally yet as not at home
                Win 10 Pro
                HS3 .206
                HSTouch Server .75
                Her account is of the type "Normal" with Event access but no access to Counters/Timers or Logs
                I am probably missing something obvious
                Cheers
                James
                cheeryfool
                • #9
                  That's why I'm asking for an option that accounts for both scenarios (no pun intended ). I'm not worried about a thief breaking into my house that way. There are enough rocks in my yard that it's easy for any one to come in that wants to come in. However, I'm worried about my kids, wife or house guests accidentally doing something to my HA system that they shouldn't be doing and I'm also worried about some hacker group somewhere launching an attack on HS systems at some point in time just to prove that they can and maybe unlocking all doors and turning of all thermostats in the middle of winter. From my perspective the latter is a matter of when, not if, as the number of IoT and connected homes grows.
                  IMHO a strong security framework will be a must if HS wants to stay a leader in the HA space. To me this means that security must be able to be seamlessly applied without having to turn it off to allow some functionality to work. Hardware devices such as the z-net should be password protected, the web server should use a current version of SSL, etc, etc.
                  Cheers
                  Al
                  • #10
                    I agree. The Z-tool should have the same configuration settings found in HSTouch client. Once credentials are entered, they can be remembered for seamless logon as required.
                    Mike
                    • #11
                      On this piece, Rich mentioned that the new versions of HS3 (I think it was .205 and later) had been modified to use the inbuilt Windows web server (presumably IIS), instead of the legacy version previously built in to HS. I would have hoped that would solve this, but I didn't get any confirmation when I asked.
                      cheeryfool
                      • #12
                        We'll look into it. FYI though... Z-Tool+ only has the ability to add/remove devices IF YOU ARE IN THE HOUSE. So again... from a security perspective, you have much bigger problems than if someone is actually in your house. Truthfully, even without Z-Tool+, you can still foul up someone's network with a little Z-Stick.
                        • #13
                          I think the real risk is that if someone launches z-tool and select add or delete, then someone else turns on a light switch, z-tool might pick it up to add or delete.
                          HS3Pro Running on a Raspberry Pi3
                          64 Z-Wave Nodes, 168 Events, 280 Devices
                          • #14
                            Delete would be the only possibility. There's no way to add a node that's already on the network. Also, delete only works in direct range. It won't work over routing.
                            Again though... what's the likelyhood that someone would go to all this trouble to mess up someone's network? What would be the end-game? You can't control any devices this way... you can't unlock a lock with Z-Tool+!
                            • #15
                              I recently installed a Hometroller Zee S2 in a 40 person ski house. I need backup admins and for training purposes I would like tech savvy people to have read-only access so they could view events and all settings without being able to change anything. Once they're familiar I can allow them full access. Is there a way to give read only access to the entire system?
