Contacting HomeSeer This Week
See more
See less
Door Bell Sensor with MySensor Arduino
  • Door Bell Sensor with MySensor Arduino
    I hope this is this is the right place to post this. I figured I have received so much help on this forum, it was time to return back. I had some parts lying around and wanted to get a sensor put on the doorbell. I already use the mysensor arduino plugin mainly because it creates a wireless network for sensors, which makes it easy to put things anywhere, but I am sure this can be moded to be used without the wireless with the other arduino plugin.
    So here goes. This started as a POC and now that its working, I wanted to get some pics for you guys before cleaning it up into a project box and making it look neat. I will also be using a nano vs the uno that is currently in the picture to make the setup smaller.
    First this is the link to the project on the mysensors site. It gives you everything you need to make this including a video and diagram:
    http://forum.mysensors.org/topic/206...utomation-hack
    If you don't have mysensor yet, check the forums here to get it setup
    Here is the updated arduino sketch as well to use for homeseer so that you can get the status change to the virtual device. I just modified one line at the bottom to have the status sent
    <!--[if gte mso 9]><xml>  <o:OfficeDocumentSettings>   <o:AllowPNG/>  </o:OfficeDocumentSettings> </xml><![endif]-->  /*
     * The MySensors Arduino library handles the wireless radio link and protocol
     * between your home built sensors/actuators and HA controller of choice.
     * The sensors forms a self healing radio network with optional repeaters. Each
     * repeater and gateway builds a routing tables in EEPROM which keeps track of the
     * network topology allowing messages to be routed to nodes.
     * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
     * Copyright (C) 2013-2015 Sensnology AB
     * Full contributor list: https://github.com/mysensors/Arduino...s/contributors
     * Documentation: http://www.mysensors.org
     * Support Forum: http://forum.mysensors.org
     * This program is free software; you can redistribute it and/or
     * modify it under the terms of the GNU General Public License
     * version 2 as published by the Free Software Foundation.
     * REVISION HISTORY
     * Version 1.0 - PeteWill
     * DESCRIPTION
     * This sketch is used to control a doorbell ring with a relay as well as send an
     * alert when the buttons is pressed.  Connect the button to ground and digital
     * pin 3.  The relay controlling the doorbell is conntected to pin 4.
     * Watch the How To video here: https://youtu.be/nMIcalwpstc
    #include <mysensor.h>
    #include <spi.h>
    #include <bounce2.h></bounce2.h></spi.h></mysensor.h>
      #define NODE_ID 18 // or set to AUTO if you want gw to assign a NODE_ID for you.
      #define DOORBELL_PIN  3      // Arduino Digital I/O pin number for the doorbell button
    #define RELAY_PIN  4         // Arduino Digital I/O pin number for the relay
    #define DOORBELL_CHILD_ID 0  //ID of the doorbell
    #define SWITCH_CHILD_ID 1    // Id of the switch that will control doorbell sound
    #define RELAY_ON 0
    #define RELAY_OFF 1
      Bounce debouncer = Bounce();
      MySensor gw;
    MyMessage switchMsg(SWITCH_CHILD_ID, V_LIGHT);
    MyMessage doorbellMsg(DOORBELL_CHILD_ID, V_TRIPPED);
      unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
    unsigned int ringTime = 700; //How long the doorbell relay is on (in milliseconds)
    unsigned long doorbellMillis;  //Used to keep track of the last doorbell button press
    unsigned long doorbellTimer;  //Used to keep track of doorbell ring time
    byte doorbellPreviousVal;  //Used to keep track of doorbell button pressed state
    boolean ringDoorbell;  //Used to initiate the ring doorbell if statement
    boolean doorbellSound; //Used to keep track if the doorbell should sound or be silent.  Value recieved from doorbell on/off switch
    boolean doorbellOff = true;  //Used to keep track of doorbell ring state
      void setup()
      gw.begin(incomingMessage, NODE_ID);
        // Send the sketch version information to the gateway and Controller
      gw.sendSketchInfo("Doorbell Monitor", "1.0");
        // Setup the button and activate internal pull-up
      pinMode(DOORBELL_PIN, INPUT_PULLUP);
        // After setting up the button, setup debouncer
      debouncer.attach(DOORBELL_PIN);
      debouncer.interval(5);
        // Register all sensors to gw (they will be created as child devices)
      gw.present(SWITCH_CHILD_ID, S_LIGHT);
      gw.present(DOORBELL_CHILD_ID, S_MOTION);
        // Make sure relays are off when starting up
      digitalWrite(RELAY_PIN, RELAY_OFF);
      // Then set relay pins in output mode
      pinMode(RELAY_PIN, OUTPUT);
        // Set doorbellSound to last known state (using eeprom storage)
      doorbellSound = gw.loadState(SWITCH_CHILD_ID);
      void loop()
      gw.process();
        unsigned long currentMillis = millis();
      //Check to see if doorbell button was pushed.
      if (currentMillis - doorbellMillis > doorbellDelay) //used to stop doorbell from being pressed too frequently
        debouncer.update();
        // Read doorbell button value
        byte doorbellDetect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
          if (doorbellDetect != doorbellPreviousVal)
          //Serial.print("doorbellDetect Value: ");
          //Serial.println(doorbellDetect);
          gw.send(doorbellMsg.set(doorbellDetect));
          if (doorbellDetect == 1)
            ringDoorbell = true;
            doorbellTimer = currentMillis;
          doorbellMillis = currentMillis;
          doorbellPreviousVal = doorbellDetect;
        if (ringDoorbell)
        if (doorbellSound)
          if (doorbellOff)
            digitalWrite(RELAY_PIN, RELAY_ON);
            //Serial.println("Doorbell sounded.");
            doorbellOff = false;
            //gw.send(switchMsg.set(doorbellSound));
          else
            if (currentMillis - doorbellTimer > ringTime)
              ringDoorbell = false;
              //Serial.println("Doorbell off.");
              doorbellOff = true;
              //gw.send(switchMsg.set(ringDoorbell));
        void incomingMessage(const MyMessage & message) {
        // We only expect one type of message from controller. But we better check anyway.
        if (message.isAck()) {
          Serial.println("This is an ack from gateway");
          if (message.type == V_LIGHT) {
          // Change relay state
          doorbellSound = message.getBool();
          // Store state in eeprom
          gw.saveState(SWITCH_CHILD_ID, doorbellSound);
          // Write some debug info
          Serial.print("Incoming change for sensor:");
          Serial.print(message.sensor);
          Serial.print(", New status: ");
          Serial.println(message.getBool());
      <!--[if gte mso 9]><xml>  <w:WordDocument>   <w:View>Normal</w:View>   <w:Zoom>0</w:Zoom>   <w:TrackMoves/>   <w:TrackFormatting/>   <w:PunctuationKerning/>   <w:ValidateAgainstSchemas/>   <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>   <w:IgnoreMixedContent>false</w:IgnoreMixedContent>   <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>   <w:DoNotPromoteQF/>   <w:LidThemeOther>EN-US</w:LidThemeOther>   <w:LidThemeAsian>X-NONE</w:LidThemeAsian>   <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>   <w:Compatibility>    <w:BreakWrappedTables/>    <w:SnapToGridInCell/>    <w:WrapTextWithPunct/>    <w:UseAsianBreakRules/>    <w:DontGrowAutofit/>    <w:SplitPgBreakAndParaMark/>    <w:EnableOpenTypeKerning/>    <w:DontFlipMirrorIndents/>    <w:OverrideTableStyleHps/>   </w:Compatibility>   <m:mathPr>    <m:mathFont m:val="Cambria Math"/>    <m:brkBin m:val="before"/>    <m:brkBinSub m:val="&#45;-"/>    <m:smallFrac m:val="off"/>    <m:dispDef/>    <m:lMargin m:val="0"/>    <m:rMargin m:val="0"/>    <m:defJc m:val="centerGroup"/>    <m:wrapIndent m:val="1440"/>    <m:intLim m:val="subSup"/>    <m:naryLim m:val="undOvr"/>   </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml>  <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false"   DefSemiHidden="false" DefQFormat="false" DefPriority="99"   LatentStyleCount="371">   <w:LsdException Locked="false" Priority="0" QFormat="true" Name="Normal"/>   <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 1"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 2"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 3"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 4"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 5"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 6"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 7"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 8"/>   <w:LsdException Locked="false" Priority="9" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="heading 9"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 6"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 7"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 8"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index 9"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 1"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 2"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 3"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 4"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 5"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 6"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 7"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 8"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" Name="toc 9"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Normal Indent"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="footnote text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="annotation text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="header"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="footer"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="index heading"/>   <w:LsdException Locked="false" Priority="35" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="caption"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="table of figures"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="envelope address"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="envelope return"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="footnote reference"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="annotation reference"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="line number"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="page number"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="endnote reference"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="endnote text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="table of authorities"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="macro"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="toa heading"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Bullet"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Number"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Bullet 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Bullet 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Bullet 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Bullet 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Number 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Number 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Number 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Number 5"/>   <w:LsdException Locked="false" Priority="10" QFormat="true" Name="Title"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Closing"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Signature"/>   <w:LsdException Locked="false" Priority="1" SemiHidden="true"    UnhideWhenUsed="true" Name="Default Paragraph Font"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text Indent"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Continue"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Continue 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Continue 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Continue 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="List Continue 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Message Header"/>   <w:LsdException Locked="false" Priority="11" QFormat="true" Name="Subtitle"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Salutation"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Date"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text First Indent"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text First Indent 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Note Heading"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text Indent 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Body Text Indent 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Block Text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Hyperlink"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="FollowedHyperlink"/>   <w:LsdException Locked="false" Priority="22" QFormat="true" Name="Strong"/>   <w:LsdException Locked="false" Priority="20" QFormat="true" Name="Emphasis"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Document Map"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Plain Text"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="E-mail Signature"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Top of Form"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Bottom of Form"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Normal (Web)"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Acronym"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Address"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Cite"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Code"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Definition"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Keyboard"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Preformatted"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Sample"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Typewriter"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="HTML Variable"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Normal Table"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="annotation subject"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="No List"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Outline List 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Outline List 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Outline List 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Simple 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Simple 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Simple 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Classic 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Classic 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Classic 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Classic 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Colorful 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Colorful 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Colorful 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Columns 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Columns 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Columns 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Columns 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Columns 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 6"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 7"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Grid 8"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 4"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 5"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 6"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 7"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table List 8"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table 3D effects 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table 3D effects 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table 3D effects 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Contemporary"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Elegant"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Professional"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Subtle 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Subtle 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Web 1"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Web 2"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Web 3"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Balloon Text"/>   <w:LsdException Locked="false" Priority="39" Name="Table Grid"/>   <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"    Name="Table Theme"/>   <w:LsdException Locked="false" SemiHidden="true" Name="Placeholder Text"/>   <w:LsdException Locked="false" Priority="1" QFormat="true" Name="No Spacing"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading"/>   <w:LsdException Locked="false" Priority="61" Name="Light List"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 1"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 1"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 1"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>   <w:LsdException Locked="false" SemiHidden="true" Name="Revision"/>   <w:LsdException Locked="false" Priority="34" QFormat="true"    Name="List Paragraph"/>   <w:LsdException Locked="false" Priority="29" QFormat="true" Name="Quote"/>   <w:LsdException Locked="false" Priority="30" QFormat="true"    Name="Intense Quote"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 1"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 1"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 2"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 2"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 2"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 2"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 2"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 3"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 3"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 3"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 3"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 3"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 4"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 4"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 4"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 4"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 4"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 5"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 5"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 5"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 5"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 5"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>   <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 6"/>   <w:LsdException Locked="false" Priority="61" Name="Light List Accent 6"/>   <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 6"/>   <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>   <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>   <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>   <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>   <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>   <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>   <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>   <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 6"/>   <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>   <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 6"/>   <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>   <w:LsdException Locked="false" Priority="19" QFormat="true"    Name="Subtle Emphasis"/>   <w:LsdException Locked="false" Priority="21" QFormat="true"    Name="Intense Emphasis"/>   <w:LsdException Locked="false" Priority="31" QFormat="true"    Name="Subtle Reference"/>   <w:LsdException Locked="false" Priority="32" QFormat="true"    Name="Intense Reference"/>   <w:LsdException Locked="false" Priority="33" QFormat="true" Name="Book Title"/>   <w:LsdException Locked="false" Priority="37" SemiHidden="true"    UnhideWhenUsed="true" Name="Bibliography"/>   <w:LsdException Locked="false" Priority="39" SemiHidden="true"    UnhideWhenUsed="true" QFormat="true" Name="TOC Heading"/>   <w:LsdException Locked="false" Priority="41" Name="Plain Table 1"/>   <w:LsdException Locked="false" Priority="42" Name="Plain Table 2"/>   <w:LsdException Locked="false" Priority="43" Name="Plain Table 3"/>   <w:LsdException Locked="false" Priority="44" Name="Plain Table 4"/>   <w:LsdException Locked="false" Priority="45" Name="Plain Table 5"/>   <w:LsdException Locked="false" Priority="40" Name="Grid Table Light"/>   <w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark"/>   <w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>   <w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 1"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 1"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 1"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 2"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 2"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 2"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 3"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 3"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 3"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 4"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 4"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 4"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 5"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 5"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 5"/>   <w:LsdException Locked="false" Priority="46"    Name="Grid Table 1 Light Accent 6"/>   <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>   <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>   <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>   <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>   <w:LsdException Locked="false" Priority="51"    Name="Grid Table 6 Colorful Accent 6"/>   <w:LsdException Locked="false" Priority="52"    Name="Grid Table 7 Colorful Accent 6"/>   <w:LsdException Locked="false" Priority="46" Name="List Table 1 Light"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark"/>   <w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful"/>   <w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 1"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 1"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 1"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 1"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 1"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 1"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 2"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 2"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 2"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 2"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 2"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 2"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 3"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 3"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 3"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 3"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 3"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 3"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 4"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 4"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 4"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 4"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 4"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 4"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 5"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 5"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 5"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 5"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 5"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 5"/>   <w:LsdException Locked="false" Priority="46"    Name="List Table 1 Light Accent 6"/>   <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 6"/>   <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 6"/>   <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 6"/>   <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>   <w:LsdException Locked="false" Priority="51"    Name="List Table 6 Colorful Accent 6"/>   <w:LsdException Locked="false" Priority="52"    Name="List Table 7 Colorful Accent 6"/>  </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style>  /* Style Definitions */  table.MsoNormalTable     {mso-style-name:"Table Normal";     mso-tstyle-rowband-size:0;     mso-tstyle-colband-size:0;     mso-style-noshow:yes;     mso-style-priority:99;     mso-style-parent:"";     mso-padding-alt:0in 5.4pt 0in 5.4pt;     mso-para-margin:0in;     mso-para-margin-bottom:.0001pt;     mso-pagination:widow-orphan;     font-size:10.0pt;     font-family:"Times New Roman",serif;} </style> <![endif]-->
    My pictures below show the relay (it's a two, but I only used one), this is tied to the power and the bell itself (completes the circuit between the two) and then the other picture shows the arduino tied to the bell switch to ground the pin 3 to trigger the relay and sounds the bell.
    With this setup you get the triggered event that you can use for whatever. I currently have it sending a push alert to the wife and I that someone is at the door and will eventually have the picture from the security cam as well once I figure that out.
    You also have the ability to disable the bell, but still get the alert. This is useful to not disturb the house during certain times of the day.
    Hope this helps someone.
    Very NICE!! Good work. I'm Saving this page. Thanks for taking the time to document and share this!
    Sent from my iPhone
    Tom
