NEW MESSAGE BOARD LIVE NOW
  • NEW MESSAGE BOARD LIVE NOW
    If you drilled into the message, you already know this! We had originally scheduled the changeover for Monday but made more progress than expected this week... so, it's live now. We hope you like the improved look and layout. Please be sure to post problems here and we'll look into them as soon as possible.
    Again great work.
    FYI - in the "Forums" section scroll to the VERY bottom and click on "Mark Feeds Read". Otherwise the "New Posts" shows basically everything as the index is new.
      Originally posted by jeubanks View Post
      Again great work.
      I see "Mark Channels Read"... assume that's what you meant.
        In the Telephone, Text, Email Integration sub-forums, almost all the posts are missing! Are you still in the process of moving over the historical stuff?
        Nonetheless -- nice job!
        Fred
        HomeSeer Pro 3.0.0.478, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
          Same...My plug-in forums are empty as well.
          Frank
            Also, some other thoughts:
            1) Is there a way to remove the "Overview" on the latest posts list? It appears to show a short bit of the original post,which is great if you haven't been following that thread, but otherwise it's just taking up a lot of space. I used to be able to see 25 thread in a small space, now I see 10 without having to click "see more" and even then, i only see maybe 5 at a time.
            2) It seems to load very slowly for me (well, slower than before).
            Frank
              Yup that's what I was meaning... sorry doing from memory with a dozen other things going on as well
                +1
                1) It's prettier, but not nearly as readable as previous.
                2) REALLY slow.. Probably because every post is being read by the system?
                Z
                  1 - Having some issues here reading the forum due to the colors used for the backround and text.
                  Here are some examples of forums that I have no issues with relating to color use.
                  Click image for larger version  Name:	forums.jpg Views:	1 Size:	101.5 KB ID:	1236515
                  - Pete
                  Auto mator
                  Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.00
                  Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.00
                    Did we lose signatures?
                    and the search wont find hits on "1-wire"; is the search working
                    Mark
                    HS3 Pro 3.0.0.435
                      If I go to my plugin forums via the "Plugins by Author" the posts are there, so there is that. But if you click on it from the home page listing of the forums, they are empty. I assume just some pointers need to be set up?
                      Frank
                        Very slow here, This should be improved otherwise the board is useless.
                          Signatures are there but you will have to enable them in your profile. Click on your name at the top then My Profile, then Account.
                          Randy Prade
                          Aurora, CO
                          Prades.net
                            Originally posted by vasrc View Post
                            +1
                            Z
                            Very slow here as well. Every function.
                            Randy Prade
                            Aurora, CO
                            Prades.net
                              This forum requires more resources than the previous one, we will be upgrading the speed and # of cores soon, I suspect that will speed it up. Will post when that is done.
