PLEASE PUT MESSAGE BOARD SUGGESTIONS HERE
  • I've received zero email notifications since the upgrade. Setting is 'On, daily' as it was before.
    Curious about the reputation bars. It was posted that there was a place to enable this on user settings account tab but I'm coming up empty finding that.
    • Originally posted by zwolfpack View Post
      User Settings > Account tab > tick the box to Enable reputation level
      Learn About HomeSeer
      • Originally posted by macromark View Post
        That setting is not on that page (at least for me). But, it does appear to be working otherwise...
        68 Z-Wave Nodes, 174 Events, 326 Devices
          That setting is MIA on my Account tab.
          • Originally posted by rmasonjr View Post
            Ditto
            Randy Prade
            Aurora, CO
            Prades.net
              Same here.
              • I do not see the "reputation" option here on the User Settings > Account tab.
                - Pete
                Auto mator
                HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
                HS4 Lite -
                • Originally posted by cc4005 View Post
                  Did as suggested, plus quit and restarted chrome after clearing the cache. Still not there. I never had a signature on the old board, although I was member of a couple groups and had the option. The ability to add a signature was definitely there after initial migration to vB5 because I started drafting one a week or so ago then cancelled it without saving.
                  I'm on cool blue. Learned my lesson with the Mark All Forums Read issue.
                  Click image for larger version Name:	Capture.PNG Views:	1 Size:	9.2 KB ID:	1239061
                  Put in a help desk ticket and we can get this fixed for anyone that doesn't have the ability to post a signature - support@homeseer.com
                  -Rupp
                  • OK, looks like your reputation was visible by default but that you coudn't hide it. Now, you should be able to see that option.
                      Thanks Mark, that got it.
                      • Anyone else having any luck with the new forum search feature. still not working for me
                        Mark
                        HS3 Pro 3.0.0.534
                        • Originally posted by mnsandler View Post
                          can you supply an example?
                            please compare the results of searching "getbuffer" here vs using "getbuffer site:homeseer.com" at google.com
                            also, the search for "1-wire" produces nothing here
                            Mark
                            HS3 Pro 3.0.0.534
                            • Here is a search screenshot Mark.
                              Same results doing an "Arduino" and "MQTT" random search.
                              Click image for larger version  Name:	1-wiresearch.jpg Views:	1 Size:	41.7 KB ID:	1239204
                              - Pete
                              Auto mator
                              HS4 Lite -
                              • I deleted the search index and am rebuilding it from scratch. Pete . Your terms do work now. mnsandler there appears to be a problem with searches that include a dash (like 1-wire). We're researching this.
