PLEASE PUT MESSAGE BOARD SUGGESTIONS HERE
  • Thank you Mark.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    • There appears to be a "Thread" level search option.Very cool! Can you add the search option to the forum level so we don't have to select the "{forum name} only" drop down option on the site level search at the top right search.
      Mark
      HS3 Pro 3.0.0.534
      • macromark
        Still at 3892 and around 389 pages of subscriptions. Been deleting one or two pages of subscriptions when I log in. It'll take forever. Is there a way you can bulk remove all of my subscriptions. They go back over 10 years.
        - Pete
        Auto mator
        HS4 Lite -
        • Originally posted by Pete View Post
          macromark
          is there a downside to be subscribed to that many threads? or are you just trying to clean house
          Mark
          HS3 Pro 3.0.0.534
          • is there a downside to be subscribed to that many threads?
            Well not really cuz I do not get emails here relating to subs.
            or are you just trying to clean house?
            It just so happened that I looked. Never have paid attention. So yes was cleaning house.
            Thinking more about it you can leave it alone and remove my request to delete all of the subs from your user request punch list.
            - Pete
            Auto mator
            HS4 Lite -
            • Relating to the in/out PM mailbox...noticed that the limit is now set to 50 and I have 87 messages saved and cannot send any PMs.
              Thinking the old forum was set to 100 and I tried to keep the messages under 100.
              macromark Can we change it back to 100?
              - Pete
              Auto mator
              HS4 Lite -
              • cheeryfool
                • I am sure a lot of the issue is the first post being sticky at the top irrespective of whether you choose newest at bottom or top. Can this be turned off?
                  cheeryfool
                  • Originally posted by mnsandler View Post
                    please compare the results of searching "getbuffer" here vs using "getbuffer site:homeseer.com" at google.com
                    also, the search for "1-wire" produces nothing here
                    Native search is still broken for terms with hyphens and we continue to work on that. As a temporary fix, the board is now configured to use Google for searches.
                    Learn About HomeSeer
                    • Originally posted by macromark View Post
                      Any love for Tapatalk Mark?
                      cheeryfool
                      • I just installed Tapatalk on my phone and browsed to this message and am replying to it. Can you tell me what the problem is?
                        Sent from my Nexus 5X using Tapatalk
                          https://forums.homeseer.com/node/101...84#post1237984
                          This post and a few others from this thread got moved to the "Tapatalk issues" forum.
                          Code block test
                          #!/bin/sh
                          echo "Hello world!"
                          exit 0
                          "Quote" test
                          This is quoted
                          So is this
                          Looks like "quote" is OK but "code" shows HTML code instead.
                          • Originally posted by zwolfpack View Post
                            Code block test
                            #!/bin/sh
                            echo "Hello world!"
                            exit 0
                            "Quote" test
                            so you're saying the code block displays OK here but not on Tapatalk? Is that the issue?
                              Yes that is the issue. However my biggest issue is the way the message indexes are shown, see the linked post. The old board showed the author and 1st line of the most recent post; this board shows the name of the most recent poster, but content from the 1st post. It's confusing.
                                I've checked the Tapatalk settings that we have control over and there does not appear to be anything I can do on this end to fix these issues... to fix how Tapatalk is taking the information and displaying it.
                                Have you tried using the forum with just a browser on your phone? The theme is now responsive and it should work well.
