Still on DST
  • Still on DST
    The time stamp is one hour ahead of actual time.
    Does the top bar of the HS3 web gui show the correct time? If you ssh to the device does it show the correct time when you type date? Assumption is that you are using Linux.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
      Pete;
      He is referring to forums.homeseer.com. This forum is for reporting problems with the forums (department of redundancy department?). The time stamps on the posts are off by an hour.
      Randy Prade
      Aurora, CO
      Prades.net
        Pete;
        Correct.
          Thanks guys!
          Yes posted and check time of post here and it is one hour ahead such that time change on forum appears not to have worked.
          Post is showing
          Today, 10:22 AM
          where it is 9:22 AM local time here in the midwest.
          - Pete
          Auto mator
            Thanks guys!
            Post is showing
            Today, 10:22 AM
            Until this gets corrected you can go into User Settings -> Account and turn off DST corrections.
            Ken
            EDIT: Oops. Interestingly enough, that setting doesn't fix the problem. How's that?
            EDIT2: It helps if you click "Save Changes" when you change the setting. Works as expected now.
              how 'bout now? looks OK to me.
              Learn About HomeSeer
                Yes sir!
                Randy Prade
                Aurora, CO
                Prades.net
                  Looks good. Back to auto-dst setting.
                    unfortunately, it's not automated on my side so... I'll look for posts in this thread again in about 6 months!
                      That's what Outlook calendar reminders are for. My wife drives a Jaguar sedan and parks in a garage which is under the house in the side of a hill. The clock on the car auto syncs via GPS but not as long as it's under the house. I wrote a note to her and left it in the owners manual saying "back out of the garage to set clock" after the third time she asked me how to change the clock in her car.
