I have multiple events that are disabled . I would like one event that will enable all at once and another one event that will disable all again. I cannot find a way to do this. Is this possible without enabling/disabling each event individually? It would be a time saver if I could.
How to Enable Multiple Events
If the events are all in one Group, you could use a Group Condition to accomplish this. I have a Group for my outside lights. I have a Virtual Device called Run Outside Events. The Group Condition is set to If Run Outside Lights Events has a value equal to On. So I set this device to On and the events iin the Outside group run. Turn it to Off and they do not.
Otherwise, if you actually need to Enable/Disable the events you may need a script.Karl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
Thanks. It's a tab more complex than the Group Conditions can handle, I think. I have 15 events. Each event, for example, turns a light on and then off (some do other things) after a period of time and depending on the time of day. I use this when I am on vacation. I would like to enable all events before I leave using one command and then disable them when I return with one command. I'm just lazy. Now, I enable each event before I leave and then disable each when I return. I tried to Occupancy PlugIn but had no joy.
Originally posted by spudbw View PostThanks. It's a tab more complex than the Group Conditions can handle, I think. I have 15 events. Each event, for example, turns a light on and then off (some do other things) after a period of time and depending on the time of day. I use this when I am on vacation. I would like to enable all events before I leave using one command and then disable them when I return with one command. I'm just lazy. Now, I enable each event before I leave and then disable each when I return. I tried to Occupancy PlugIn but had no joy.Len
HomeSeer Version: HS3 Pro Edition 3.0.0.435
Linux version: Linux homeseer Ubuntu 16.04 x86_64
Number of Devices: 633
Number of Events: 773
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
3.0.0.48: EasyTrigger
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.0.87: weatherXML
3.0.1.190: Z-Wave
I have 11 events in my Outside group and the Group Condition works well. Some are set to run and others are disabled. The only time any which are set to run do run is when the condition is true. In this case my Virtual Device called Run Outside Events is set to On. The ones which have Never run would not have run yet for various reasons, such as one is Manually run. So the internal conditions for each event still apply, the Group Condition just determines if the Events which are set to run will be checked to possibly run. So I use this as a way to enable or disable these events as a Group.
Karl S
1070 Devices
56 Z-Wave Nodes
104 Events
this is something I wanted to do in HS2... and didn't.. then never did in HS3... whelp.. HS4 sounds like I gotta get on the ball!!!!!
kinda reminds me of the ... Is Holiday...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
