If you'd like to display your HomeSeer system in your posts, you can do this without the need for a signature. Just access your user settings, look for the "HS System" field and type your system in.
HOWEVER, please limit this to the HomeTroller you're using or the HomeSeer software you're using and OS. You'll be limited to 18 characters. If you're running HS4PRO on a Linux box, if should just be "HS4PRO, Linux".
Your system will appear in each post under your location.
In my case, I'm using a HomeTroller Plus... you can see that at the left
