Caméra et souscription pros
    Hello
    J’habite en france et impossible d’avoir un enregistrement de caméra avec hs4 j’ai la souscription pros pour 10 caméras
    Pouvez-vous vous m’aider
    Merci
    Envoyé de mon iPhone en utilisant Tapatalk
    Welcome to the Homeseer forum Laurent. Your message would be better written in English. Used Google translate.
    I live in France and cannot have a camera recording with hs4 I have the pros subscription for 10 cameras Can you help me.
    I have never tried to enable more than one camera here in HS4 Pro or Lite.
    I use Zoneminder / BI here for my cameras mostly and only have tested HS4 to work with the cameras.
    - Pete
    Auto mator
    Fanless Intel® Celeron N3160 SoC 8Gb
      Hello,
      How are you triggering the recording option for you camera? You have to setup and event to "trigger" the capture.
      -Rupp
        Hello and Thank you for your answers yes I did an event Trigger but I have the code Warning after 2 tries could not record from camera Cam_2eme .
        I wanted to be able to save my recordings remotely.
        Thank you for your help there are not many French people who use HS4, I started with HS2 and intend to remain faithful
