Help with HS4 problem
    Suddenly I can't edit any of my devices. I get this message when I try:
    Error generating tab: The given key was not present in the dictionary.
    I've restarted HS4 but it didn't help.
    Date/time=12/2/2021 1:57:05 PM Central Standard Time
    Version=HS4 Pro Edition 4.2.6.0 (Windows)
    License=Registered
    Confguration File=C:\Program Files (x86)\HomeSeer HS4\Data\Joneses.json
    In Virtual Machine=No MFG: gigabyte technology co., ltd.
    Antivirus=Windows Defender Norton 360 Norton 360
    OS=Microsoft Windows 10 Pro - Work Station
    OS Version=10.0.19043
    Uptime=2 Days 4 Hours 22 Minutes 30 Seconds
    Lan IP=192.168.1.10 (Desktop-Control)
    Device Count=336
    Event Count=152
    Processor:=Intel64 Family 6 Model 158 Stepping 13 at 3.35 GHz
    Modules/Threads=159 Modules, 142 Threads
    Available Threads=1023
    System Load=231 Processes, 10% Load
    Free/Total Memory=21.97 GBytes / 31.93 GBytes (69% free)
    Free/Total Virtual Memory=24.20 GBytes / 36.68 GBytes (66% free)
    HomeSeer Memory Used=280 Mbytes
    Plugin Memory Used=19 EXE Plug-Ins using 743 Mbytes
    Plugins Installed=AmbientWeather 3.0.1.9,BLBackup 2.0.63.0,BLLAN 2.0.45.0,BLLock 3.0.38.0,BLRF 2.0.96.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,EasyTrigger 3.0.0.74,EnvisaLinkAdemco 3.0.0.31,Harmony Hub 4.0.13.0,Honeywell WiFi Thermostat 1.4.2.2,HS MyQ 4.0.7.0,HSBuddy 3.26.1114.49,IFTTT 3.0.1.4,Insteon 3.0.7.1,Life360 3.0.0.326,OpenSprinkler 2.1.9.2,Tasker Plugin 3.0.4.6,Tuya 4.0.30.0,Z-Wave 3.0.9.0
    Where are you trying to edit your devices? What value are you trying to edit? Does this happen with all devices or just one or some?
      click on device name and get the message. It went away for a while and worked fine. Then it came back again. It's all devices
        Did you ever get this resolved and if so how? It just started happening for me yesterday.
          Does this mean that you could not change location 1 and location 2? I had this item a few weeks ago but did not had a look in the log.
          John
            Like jrjmpls7 stated, if I click on any device I get the error Error generating tab: The given key was not present in the dictionary. Not sure what happen, I found it yesterday but had worked fine the day before. I'm running HS4 on a Windows 10 PC.
              It's most likely a JSON issue. Do you have a recent backup? Did you change something yesterday just prior to this issue?
              -Rupp
                Homeseer Support recommended that I upgrade Homeseer and the Zwave plugin to the latest version, which I did. It fixed the problem but what was strange was that at first it appeared that it didn't. I had to close and restart the browser (Edge) to see that it was fixed.
