How to cut and paste log data to board posts?
  • How to cut and paste log data to board posts?
    trying to cut and paste log data from HS2 web Log page to foirum.. and it doesn't work as i would expect.
    I tried the [code] and [php] tagss... and nothing seems to work..
    It seems to just do one line
    See examples:
    Code tag
    7/28/2012 5:40:51 PM Vista Alarm [0010000110000000----],008,[f70000071008008c28020000000000],"ARMED ***STAY*** "7/28/2012 5:41:01 PM Vista Alarm Ignoring Message7/28/2012 5:41:01 PM Vista Alarm [0010000110000000----],008,[f70000071008008c28020000000000],"ARMED ***STAY*** "
    PHP tag
    PHP Code:
    HTML Tag
    HTML Code:
    Nothing seems to work?
    Andrew B.
    Are you opening the HomeSeer.log file for your cut and paste?
    -Rupp
      No... Just highlighting from HS web interface log page...
      It would prob work from the text log file... Didn't think of that,
      It's probably something having to do with c&p from web page..
      Thanks for the idea... I'll try that in a bit
      Andrew B.
        I've found that if I first paste into Notepad, then I can usually copy and paste from there into a message pane without a problem.
        HS3 Pro Edition 3.0.0.548
          If there are log entries with strings with images then it doesn't work.
          I usually then do a screen grab/picture of the log entry.
          - Pete
          Auto mator
          Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
          Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
            Kind of like UM, I also use something to strip out all the HTML goodies...
            I run PureText
            http://www.stevemiller.net/
            Now, instead of control-V, I use Window-V, which basically does the same thing as opening Notepad, pasting into there, then copying and re-pasting. This takes care of all that for you.
            --Dan
            Tasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
