Originally posted by rjh
View Post
PLEASE PUT MESSAGE BOARD SUGGESTIONS HERE
Originally posted by lakemirror View PostWhat am I doing wrong? When this event triggers, it sends about a dozen emails. It's got to be something moronic that I've done. Could use some help.
Sent from my Galaxy S7 Edge using Tapatalk
72 Z-Wave Nodes, 111 Events, 422 Devices
Z-Wave, UPB, WiFi
Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
Originally posted by rprade View PostThe vBulletin logo is still on the browser tab.
Sent from my iPhone using TapatalkHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
Originally posted by ando1 View Post
Thanks Frank,
In order to make sure there was nothing wrong with my hub, I purchased a new hub and replaced it with the original failing one named "Family Room". The new hub is named "FamilyRoom2" and did fail in the same way, so I downloaded the EXE you posted and replaced it like you said. The logs are attached. Also I am posing a screen shot of my hubs in the configuration screen so you can see the HubID for each one. I highlighted the new failing hub.
[ATTACH]n1236764[/ATTACH]
So you can't even enable it, can you? It adds, but won't enable. I'll check the logs out.
Can you do me a favor though and plug your Harmony Hub in next to your other one (the one that works) and see if it works in that location. I think it's odd that one is working, but not the others.
A couple of things I have noticed:
1. Native forum search seems to be worse than on the old version. Searching for "teslaseer" returns no results. Searching for "tesla" returns results for TeslaSeer. Thankfully Google search still works
2. I like to look at posts from the last 2 days with the newest at the top. Previously I was using the following bookmarked URL for the last 2 days and had the 'newest at top' option set in the forum settings: board.homeseer.com/search.php?do=getdaily&days=2 I can't figure out how to set an equivalent 2 day filter so far.
3. Tapatalk for iOS isn't as clean as I previously indicated. It may be due to the original post always being at the top of the new forum, but the newest user and post are not in sync. e.g. the latest poster is the user ID on the top message, but the content is the original post.cheeryfool
Originally posted by monument View Postok appreciate the response. it's frustrating when manufacturers act that way. i know there are others using HS3 who want to use/buy the MCA88.... i'm an authorized Russound dealer -- mind if I ping them about it?
Sent from my iPad using TapatalkPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Any idea when TapaTalk is going to work with the new board? I've logged out and back in with both phone and iPad but I never get any notifications of new posts, if I've posted to a thread before I used to get a notification that someone replied.
Has the issue been fixed with single and double quotes on iPad? Sorry if I'm behind but since this new board, everything that I had setup has broken.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Does anyone know if you have to turn on email notifications in order to get Tapatalk notifications to work again?
HS3 3.0.0.423 & HSTouch 3.0.55 with 700 Devices, 358 Events
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.206HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Sorry, don't use Tapatalk. The link you mention appears to show all the threads in which you've posted. Is that what you were looking for? "My profile" lists the actual posts, but extracts them from the threads.Mike____________________________________________________________ __________________
I can’t get Tapatalk to work the way it used to. I like the newest posts at the top and for it to take me to the next newest unread when I return. That was all fine on the old board. Now in the latest posts list I always see the content on the original post but with the name of the latest poster. Drilling into the threads seems to have mixed results as to which order and location I end up in. Part of it maybe that the new board on a PC seems to always show the first post on top of the list even though for me the latest post is right beneath it. I seem to be losing touch with the forum...cheeryfool
- Likes 1
