Tapatalk on iOS has been down for me in same way since about Friday as well.
Update to forum today broke Tapatalk
Originally posted by jseer View PostUpdate: I am trying to work with Tapatalk but as of right now we pinpoint the issue is difficult. We still have our usual connections and people are actively using our forum via tapatalk at our normal activity levels, so it is working. Why your 4 specific accounts are not working, is a bit of an unknown right now.
Mine is not working either. I’m using Tapatalk pro if that matters. Same error as MDA._______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
If it does work, I would not be excited to lose my current user name and history but it would be nice to get access back via Tapatalk.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Other forums work well for me in Tapatalk. The only forum I’ve ever had an issue with is this new homeseer forum. Now it is really broken. Previously if I logged out I could at least read posts. Now everything is completely blocked except forum structure. No posts are visible-just folders._______________________________________________
Originally posted by jlrichar View PostOther forums work well for me in Tapatalk. The only forum I’ve ever had an issue with is this new homeseer forum. Now it is really broken. Previously if I logged out I could at least read posts. Now everything is completely blocked except forum structure. No posts are visible-just folders.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
When you are logged out of the forum, not Tapatalk, you can still read posts (previously). You just could see unread or reply. Same as the regular and mobile forum sites._______________________________________________
Originally posted by jseer View PostTapatalk got back to us with a fix and I have implemented it. Please try and log in again. They were aware of the issue with with the newest version of VB. I was able to successfully log in after implementing the fix. Please confirm. I appreciate your patience in handling this issue.HS 4.2.8.0: 2134 Devices 1252 Events
Guest
jseer Hi Jon, not sure if this will post or not but I tried to post to the forum via Tapatalk and it said that my post had to be approved before it would show up. If this post I’m creating now (via web browser) shows up then it is just Tapatalk related.
Thank you for your help with this!HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
