Anyway to update Ubuntu in Hometroller SEL?
    #16
    I did test the new configuration with the CM11A and it works in Ubuntu 18.04...not sure why it does and the CM15A doesn't but at least I have a working alternative. Thanks!
      #17
      The CM15A is a bit different than the CM11A as it has propietary USB drivers and the CM11A is just using a stanard serial to USB.
      Guessing you have read this post ==> CM15A and Linux
      - Pete
      Auto mator
      Fanless Intel® Celeron N3160 SoC 8Gb
        #18
        I have read that post, but I’m already running the latest and only Linux plug-in for the CM15A.
        Do you updating mochad to the latest release would fix my problem?
          #19
          FYI, I rebuilt my HomeSeer SEL on Ubuntu 18.04 and installed Mochad 0.1.17 (which is actually the latest version available) and my CM15A is working properly now.
