Is there any zigbee interface that will work on the SEL platform? Very disappointing that the Nortek stick is STILL unsupported..
Homeseer SEL Pro and Zigbee
zigbee2mqtt uses a TI USB Zigbee interface. I have distributed many of these for $10 and should have some left. It uses the mcsMQTT plugin. The physical device is managed with a nodejs service. I have not explicitly tried it on SEL, but I have on various RPi flavors. I can try on the Hometroller Pi and look to see if I have any more if you are interested.
I did confirm that I have a USB dongle for Zigbee. I also installed zigbee2mqtt on Hometroller Pi using the instructions at Running Zigbee2MQTT | zigbee2mqtt.io. No issues with install. I installed mcsMQTT from Updater. I went to General tab and changed the Broker from localhost to a blank text box. This started the internal MQTT broker. I then saw the messages from zigbee2mqtt appear on the mcsMQTT Statistics tab.
Bottom line is that zigbee2mqtt works with Hometroller Pi which should be the same as SEL.
