Homeseer Sel Pro stops controlling daily
    I had to go out of town but I am back. I am running a Homeseer Sel- Pro and I am trying to add another controller in my garage. It is a homeseer z-interface. I now have two major problems.
    One: the Sel with my Z-stick is stopping controlling. I am using this as my main controller. With my limited knowlodge of these things, it seems a little strange that a 800.00 box relys on a 40.00 z-stick to work, but...OK. All of my devices are loaded. I have many control scenes built and they are trying to work. So, I have the jest of this thing. But.... for some reason, when I get up in the morning, it has lost total control. Nothing works. If I get on my cell and try to get it on line, it won't even talk. I have to pull the plug on it, let it sit and then plug it back in.
    Has anyone had this problem at all? It cannot just be this hardware. I would figure anyone using a stick could have it. Hey, if I have to start over I will, but my garage door programs took me a day to build. I just don't want to lose them. Help!! and no, I see no error in the logs.
    TWO:
    I lost connection with the z-wave interface box. I keep trying to get it to comunicate but it won't. Help
    I have been having a similar problem with my SEL. It just locks up and will not respond to anything. I have to manually turn it off and back on to get it working again and it funs fine for a while then happens again.
    I bought this unit because I thought it would be rock stable. But at least 1x / day it just locks up.
    Mine is all caught up on all updates etc.
    Hopefully someone will respond with ideas.
      Is the SEL Pro a Windows unit or Linux unit?
        I have had this happen one time since I bought my SEL about a month or two ago. I had to do a hard reboot of the device; could not get into it with SCP or Putty, and could not control it.
        When I rebooted it, it seemed that the device was running very warm. There are no fans in it, and mine sits under a desk in a tray. I wondered at that time if heat wasn't the culprit, but I have not had a repeat of the problem since.
          Hmmm. I would probably contact HST for an exchange. So long as power is not cut, I've had an SEL PRO go six months without ever rebooting it -- and it would've gone longer, but I did an update that necessitated a reboot.
          At our current place, I just checked and the SEL has been running 65 days non-stop.
            SEL still random lockups
            I have the std SEL and still get random lockups. It may go 12 hours or 3 days. I have run the update system software tool several time so should be up to date but still have times where the unit will just not respond to anything other than pull plug and reboot.
            Do I need to get a clean version from HS to start over?
            Thanks!
              Btw, I have noticed that when it licks up the network light on the z-net unit is red. Once rebooted it goes green again.
                If you are using Gmail on your SEL, you may want to look at this thread ...
                https://forums.homeseer.com/showthread.php?t=187135
                I am still having this Gmail related problem occasionally at random. The result is that it causes HS3 to crash at which point the SEL has lost control. Turning the power off then on brings it back up again.
                Have not had a response from HS on the problem nor has the bug report I lodged been acted on.
                BTW, in order to diagnose this problem, you'll need to install UltraLog3. The HS3 log resets on a reboot/restart, so whatever caused the crash won't be logged. Ultralog will retain the log and show you what was happening right up to a crash.
                  I am having exactly the same issue. I have been using HS3 for around 6 months and when it's working its amazing - way better than my old Vera setup but my SEL-Pro just seems to lock intermittently (its on latest updates). Interestingly I decided to bite the bullet and purchased a new HS3 license during the recent sale for a Windows laptop I have lying around. I am using the same Z-Wave USB stick as before and there is no change in the various devices I'm using but now have a fully reliable system.
                  I thought using a Linux backbone would be way more stable than Windows but in my case its proved the opposite.
                    I am having the same issue i found the following messages in the syslog right before the system goes down. it looks like some tyoe of kernel panic
                    Nov 28 12:52:37 hometrollerSEL kernel: [169094.898834] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00fffc00)
                    Nov 28 12:52:37 hometrollerSEL kernel: [169095.015019] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00fff000)
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024547] ------------[ cut here ]------------
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024607] WARNING: CPU: 0 PID: 188 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024611] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024613] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024707] CPU: 0 PID: 188 Comm: kworker/0:2 Not tainted 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024710] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024725] Workqueue: events output_poll_execute [drm_kms_helper]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024729] c1ae9967 aca76668 00000286 f2c79d68 c13af19f f2c79da8 f8804904 f2c79d98
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024737] c1070457 f8806f98 f2c79dc8 000000bc f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024744] 00000000 f8783110 f881a5e8 f2c79db4 c10704ce 00000009 f2c79da8 f8806f98
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024752] Call Trace:
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024762] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024768] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024815] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024860] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024904] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024909] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024954] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.024994] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025034] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025080] [<f87be590>] intel_crt_detect+0x260/0x970 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025085] [<c10a0a03>] ? set_next_entity+0xe3/0xcd0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025089] [<c10a7173>] ? put_prev_entity+0x33/0xcc0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025094] [<c10aa439>] ? pick_next_task_fair+0x459/0x520
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025107] [<f85a97e4>] output_poll_execute+0xc4/0x1c0 [drm_kms_helper]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025112] [<c10879e1>] process_one_work+0x121/0x3f0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025117] [<c1087ce7>] worker_thread+0x37/0x490
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025121] [<c108d183>] kthread+0xb3/0xd0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025125] [<c1087cb0>] ? process_one_work+0x3f0/0x3f0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025131] [<c17c6849>] ret_from_kernel_thread+0x21/0x38
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025135] [<c108d0d0>] ? kthread_create_on_node+0x170/0x170
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025139] ---[ end trace 97e8e647489024c8 ]---
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025142] ------------[ cut here ]------------
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025187] WARNING: CPU: 0 PID: 188 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025190] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025192] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025269] CPU: 0 PID: 188 Comm: kworker/0:2 Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025271] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025283] Workqueue: events output_poll_execute [drm_kms_helper]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025286] c1ae9967 aca76668 00000286 f2c79d68 c13af19f f2c79da8 f8804904 f2c79d98
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025293] c1070457 f8806f98 f2c79dc8 000000bc f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025301] 00000000 f8783110 f881a5e8 f2c79db4 c10704ce 00000009 f2c79da8 f8806f98
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025308] Call Trace:
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025313] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025318] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025363] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025408] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025451] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025456] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025501] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025540] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025580] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025626] [<f87be590>] intel_crt_detect+0x260/0x970 [i915]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025630] [<c10a0a03>] ? set_next_entity+0xe3/0xcd0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025634] [<c10a7173>] ? put_prev_entity+0x33/0xcc0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025639] [<c10aa439>] ? pick_next_task_fair+0x459/0x520
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025652] [<f85a97e4>] output_poll_execute+0xc4/0x1c0 [drm_kms_helper]
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025656] [<c10879e1>] process_one_work+0x121/0x3f0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025661] [<c1087ce7>] worker_thread+0x37/0x490
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025665] [<c108d183>] kthread+0xb3/0xd0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025669] [<c1087cb0>] ? process_one_work+0x3f0/0x3f0
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025674] [<c17c6849>] ret_from_kernel_thread+0x21/0x38
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025678] [<c108d0d0>] ? kthread_create_on_node+0x170/0x170
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.025681] ---[ end trace 97e8e647489024c9 ]---
                    Nov 28 12:52:38 hometrollerSEL kernel: [169096.145875] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00fff000)
                    Nov 28 12:52:39 hometrollerSEL kernel: [169096.262701] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00ffc000)
                    Nov 28 12:52:39 hometrollerSEL kernel: [169096.379144] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00ff0000)
                    Nov 28 12:52:39 hometrollerSEL kernel: [169096.499326] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00fc0000)
                    Nov 28 12:52:39 hometrollerSEL kernel: [169096.619514] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:39 hometrollerSEL kernel: [169096.739700] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838462] ------------[ cut here ]------------
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838523] WARNING: CPU: 0 PID: 188 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838526] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838528] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838622] CPU: 0 PID: 188 Comm: kworker/0:2 Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838624] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838640] Workqueue: events output_poll_execute [drm_kms_helper]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838644] c1ae9967 aca76668 00000286 f2c79dcc c13af19f f2c79e0c f8804904 f2c79dfc
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838652] c1070457 f8806f98 f2c79e2c 000000bc f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838659] 00000000 f8783110 f881a5e8 f2c79e18 c10704ce 00000009 f2c79e0c f8806f98
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838667] Call Trace:
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838676] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838683] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838730] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838775] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838819] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838824] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838869] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838909] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838948] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.838995] [<f87c99e0>] ? intel_dp_detect_dpcd+0x20/0x110 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839041] [<f87c9ba0>] intel_dp_detect+0xd0/0x4e0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839047] [<c10aa439>] ? pick_next_task_fair+0x459/0x520
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839060] [<f85a97e4>] output_poll_execute+0xc4/0x1c0 [drm_kms_helper]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839065] [<c10879e1>] process_one_work+0x121/0x3f0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839070] [<c1087ce7>] worker_thread+0x37/0x490
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839075] [<c108d183>] kthread+0xb3/0xd0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839079] [<c1087cb0>] ? process_one_work+0x3f0/0x3f0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839085] [<c17c6849>] ret_from_kernel_thread+0x21/0x38
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839089] [<c108d0d0>] ? kthread_create_on_node+0x170/0x170
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839092] ---[ end trace 97e8e647489024ca ]---
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839095] ------------[ cut here ]------------
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839141] WARNING: CPU: 0 PID: 188 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839144] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839146] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839222] CPU: 0 PID: 188 Comm: kworker/0:2 Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839225] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839237] Workqueue: events output_poll_execute [drm_kms_helper]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839239] c1ae9967 aca76668 00000286 f2c79dcc c13af19f f2c79e0c f8804904 f2c79dfc
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839247] c1070457 f8806f98 f2c79e2c 000000bc f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839254] 00000000 f8783110 f881a5e8 f2c79e18 c10704ce 00000009 f2c79e0c f8806f98
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839262] Call Trace:
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839267] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839272] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839317] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839362] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839406] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839411] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839456] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839495] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839535] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839582] [<f87c99e0>] ? intel_dp_detect_dpcd+0x20/0x110 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839628] [<f87c9ba0>] intel_dp_detect+0xd0/0x4e0 [i915]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839633] [<c10aa439>] ? pick_next_task_fair+0x459/0x520
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839645] [<f85a97e4>] output_poll_execute+0xc4/0x1c0 [drm_kms_helper]
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839650] [<c10879e1>] process_one_work+0x121/0x3f0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839655] [<c1087ce7>] worker_thread+0x37/0x490
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839659] [<c108d183>] kthread+0xb3/0xd0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839663] [<c1087cb0>] ? process_one_work+0x3f0/0x3f0
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839668] [<c17c6849>] ret_from_kernel_thread+0x21/0x38
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839672] [<c108d0d0>] ? kthread_create_on_node+0x170/0x170
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.839675] ---[ end trace 97e8e647489024cb ]---
                    Nov 28 12:52:42 hometrollerSEL kernel: [169099.966701] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:42 hometrollerSEL kernel: [169100.167010] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:43 hometrollerSEL kernel: [169100.285259] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:43 hometrollerSEL rc.local[1060]: 11/28/2017 12:52:43 PM Received string: @SYS:MODELNAME=RX-V675
                    Nov 28 12:52:43 hometrollerSEL rc.local[1060]: SYS:MODELNAME=RX-V675
                    Nov 28 12:52:43 hometrollerSEL rc.local[1060]: 11/28/2017 12:52:43 PM Updates device: SYS MODELNAME with: RX-V675
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293562] ------------[ cut here ]------------
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293622] WARNING: CPU: 1 PID: 733 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293625] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293628] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293723] CPU: 1 PID: 733 Comm: Xorg Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293726] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293729] c1ae9967 0e1e7263 00203286 f2109bd8 c13af19f f2109c18 f8804904 f2109c08
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293737] c1070457 f8806f98 f2109c38 000002dd f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293745] 00000000 f8783110 f881a5e8 f2109c24 c10704ce 00000009 f2109c18 f8806f98
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293752] Call Trace:
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293762] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293769] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293817] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293862] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293906] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293911] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293956] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.293996] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294036] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294082] [<f87be590>] intel_crt_detect+0x260/0x970 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294088] [<c11f2d10>] ? poll_select_copy_remaining+0x130/0x130
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294093] [<c11f2d01>] ? poll_select_copy_remaining+0x121/0x130
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294108] [<f85a9d4b>] drm_helper_probe_single_connector_modes_merge_bits+0x20b/0x480 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294113] [<c11fb932>] ? __fget_light+0x22/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294118] [<c17c4180>] ? mutex_lock+0x10/0x30
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294131] [<f85a9fd7>] drm_helper_probe_single_connector_modes+0x17/0x20 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294161] [<f851cb1d>] drm_mode_getconnector+0x28d/0x320 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294188] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294211] [<f850e4ae>] drm_ioctl+0x14e/0x500 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294238] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294262] [<f850e360>] ? drm_getmap+0xc0/0xc0 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294267] [<c11f2072>] do_vfs_ioctl+0x2e2/0x530
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294272] [<c11e4513>] ? SyS_fstat64+0x33/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294277] [<c11f2328>] SyS_ioctl+0x68/0x80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294282] [<c100385d>] do_fast_syscall_32+0x8d/0x150
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294286] [<c17c68dc>] sysenter_past_esp+0x3d/0x61
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294290] ---[ end trace 97e8e647489024cc ]---
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294293] ------------[ cut here ]------------
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294343] WARNING: CPU: 1 PID: 733 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294345] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294347] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294428] CPU: 1 PID: 733 Comm: Xorg Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294431] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294433] c1ae9967 0e1e7263 00203286 f2109bd8 c13af19f f2109c18 f8804904 f2109c08
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294441] c1070457 f8806f98 f2109c38 000002dd f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294448] 00000000 f8783110 f881a5e8 f2109c24 c10704ce 00000009 f2109c18 f8806f98
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294456] Call Trace:
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294462] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294468] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294515] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294560] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294603] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294608] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294653] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294693] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294733] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294779] [<f87be590>] intel_crt_detect+0x260/0x970 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294784] [<c11f2d10>] ? poll_select_copy_remaining+0x130/0x130
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294788] [<c11f2d01>] ? poll_select_copy_remaining+0x121/0x130
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294803] [<f85a9d4b>] drm_helper_probe_single_connector_modes_merge_bits+0x20b/0x480 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294807] [<c11fb932>] ? __fget_light+0x22/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294812] [<c17c4180>] ? mutex_lock+0x10/0x30
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294824] [<f85a9fd7>] drm_helper_probe_single_connector_modes+0x17/0x20 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294853] [<f851cb1d>] drm_mode_getconnector+0x28d/0x320 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294880] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294903] [<f850e4ae>] drm_ioctl+0x14e/0x500 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294930] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294954] [<f850e360>] ? drm_getmap+0xc0/0xc0 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294958] [<c11f2072>] do_vfs_ioctl+0x2e2/0x530
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294963] [<c11e4513>] ? SyS_fstat64+0x33/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294967] [<c11f2328>] SyS_ioctl+0x68/0x80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294972] [<c100385d>] do_fast_syscall_32+0x8d/0x150
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294976] [<c17c68dc>] sysenter_past_esp+0x3d/0x61
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.294979] ---[ end trace 97e8e647489024cd ]---
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.422171] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.537957] [drm:vlv_set_power_well [i915]] *ERROR* timeout setting power well state 00000000 (00f00000)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617511] ------------[ cut here ]------------
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617571] WARNING: CPU: 1 PID: 733 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617574] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617577] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617672] CPU: 1 PID: 733 Comm: Xorg Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617674] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617678] c1ae9967 0e1e7263 00203286 f2109c50 c13af19f f2109c90 f8804904 f2109c80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617686] c1070457 f8806f98 f2109cb0 000002dd f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617694] 00000000 f8783110 f881a5e8 f2109c9c c10704ce 00000009 f2109c90 f8806f98
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617701] Call Trace:
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617711] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617717] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617766] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617811] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617855] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617860] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617905] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617945] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.617984] [<f87456fc>] ? vlv_dpio_cmn_power_well_enable+0x5c/0xb0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618023] [<f87478b4>] ? intel_runtime_pm_get+0x44/0x80 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618063] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618109] [<f87be143>] ? intel_crt_get_edid+0x63/0x90 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618155] [<f87be211>] intel_crt_get_modes+0x61/0x90 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618170] [<f85a9c1f>] drm_helper_probe_single_connector_modes_merge_bits+0xdf/0x480 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618175] [<c11fb932>] ? __fget_light+0x22/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618189] [<f85a9fd7>] drm_helper_probe_single_connector_modes+0x17/0x20 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618218] [<f851cb1d>] drm_mode_getconnector+0x28d/0x320 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618245] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618268] [<f850e4ae>] drm_ioctl+0x14e/0x500 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618294] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618319] [<f850e360>] ? drm_getmap+0xc0/0xc0 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618323] [<c11f2072>] do_vfs_ioctl+0x2e2/0x530
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618329] [<c11e4513>] ? SyS_fstat64+0x33/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618333] [<c11f2328>] SyS_ioctl+0x68/0x80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618338] [<c100385d>] do_fast_syscall_32+0x8d/0x150
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618344] [<c17c68dc>] sysenter_past_esp+0x3d/0x61
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618360] ---[ end trace 97e8e647489024ce ]---
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618364] ------------[ cut here ]------------
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618414] WARNING: CPU: 1 PID: 733 at /build/linux-CXx29r/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1168 assert_pll+0x9e/0xd0 [i915]()
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618417] PLL state assertion failure (expected off, current on)
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618419] Modules linked in: ftdi_sio usbserial bnep intel_rapl arc4 intel_soc_dts_iosf rtl8723be intel_powerclamp btcoexist rtl8723_common coretemp rtl_pci rtlwifi mac80211 kvm_intel snd_intel_sst_acpi snd_intel_sst_core snd_soc_sst_mfld_platform snd_soc_rt5640 snd_soc_rl6231 kvm irqbypass snd_soc_core btusb punit_atom_debug snd_hda_codec_hdmi crc32_pclmul btrtl snd_compress snd_hda_codec_realtek snd_hda_codec_generic ac97_bus btbcm input_leds btintel snd_pcm_dmaengine cfg80211 serio_raw snd_hda_intel bluetooth snd_hda_codec cdc_acm snd_seq_midi snd_hda_core snd_seq_midi_event snd_hwdep snd_rawmidi mei_txe lpc_ich snd_pcm mei snd_seq shpchp snd_seq_device snd_timer snd 8250_fintek dw_dmac dw_dmac_core rfkill_gpio soundcore spi_pxa2xx_platform i2c_designware_platform i2c_designware_core 8250_dw snd_soc_sst_acpi pwm_lpss_platform mac_hid pwm_lpss binfmt_misc parport_pc ppdev lp parport autofs4 i915 i2c_algo_bit drm_kms_helper syscopyarea r8169 sysfillrect sysimgblt fb_sys_fops mii drm ahci libahci video i2c_hid fjes hid sdhci_acpi sdhci
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618502] CPU: 1 PID: 733 Comm: Xorg Tainted: G W 4.4.0-101-generic #124-Ubuntu
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618504] Hardware name: GIGABYTE GB-BXBT-2807/MZBAYAP-00, BIOS F4 07/15/2014
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618507] c1ae9967 0e1e7263 00203286 f2109c50 c13af19f f2109c90 f8804904 f2109c80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618515] c1070457 f8806f98 f2109cb0 000002dd f8804904 00000490 f879d83e f879d83e
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618522] 00000000 f8783110 f881a5e8 f2109c9c c10704ce 00000009 f2109c90 f8806f98
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618530] Call Trace:
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618535] [<c13af19f>] dump_stack+0x58/0x79
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618541] [<c1070457>] warn_slowpath_common+0x87/0xc0
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618588] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618633] [<f879d83e>] ? assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618677] [<f8783110>] ? gen8_write64+0x1d0/0x1d0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618681] [<c10704ce>] warn_slowpath_fmt+0x3e/0x60
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618727] [<f879d83e>] assert_pll+0x9e/0xd0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618766] [<f87455ab>] vlv_dpio_cmn_power_well_disable+0x2b/0xc0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618805] [<f87456fc>] ? vlv_dpio_cmn_power_well_enable+0x5c/0xb0 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618845] [<f87478b4>] ? intel_runtime_pm_get+0x44/0x80 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618884] [<f8747b5f>] intel_display_power_put+0xbf/0x180 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618930] [<f87be143>] ? intel_crt_get_edid+0x63/0x90 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618976] [<f87be211>] intel_crt_get_modes+0x61/0x90 [i915]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618991] [<f85a9c1f>] drm_helper_probe_single_connector_modes_merge_bits+0xdf/0x480 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.618995] [<c11fb932>] ? __fget_light+0x22/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619008] [<f85a9fd7>] drm_helper_probe_single_connector_modes+0x17/0x20 [drm_kms_helper]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619037] [<f851cb1d>] drm_mode_getconnector+0x28d/0x320 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619064] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619087] [<f850e4ae>] drm_ioctl+0x14e/0x500 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619113] [<f851c890>] ? drm_mode_getcrtc+0x140/0x140 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619138] [<f850e360>] ? drm_getmap+0xc0/0xc0 [drm]
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619142] [<c11f2072>] do_vfs_ioctl+0x2e2/0x530
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619147] [<c11e4513>] ? SyS_fstat64+0x33/0x50
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619151] [<c11f2328>] SyS_ioctl+0x68/0x80
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619156] [<c100385d>] do_fast_syscall_32+0x8d/0x150
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619160] [<c17c68dc>] sysenter_past_esp+0x3d/0x61
                    Nov 28 12:52:44 hometrollerSEL kernel: [169101.619164] ---[ end trace 97e8e647489024cf ]---
                      Are you running the Mark Sandlers Insteon plugin by any chance? At one time the Windows version was crashing with a FTDI error so I wonder if it could be the same issue?
                      -Rupp
                        S6 Pro HS shut down
                        I had the same problem last night. I have been using it for about two weeks now. Came home last night and "things weren't working" (as my wife would say). Went to unit and Windows was operational, speaker was in error (no HS) and Homeseer was not running. Unit is on a battery back up. Have Napco and GTS CPUXA as only plugins. No obvious errors and I don't think there is a log to check after HS shuts down, is there.
                          I would recommend opening up a new thread as this one is for the SEL and your's is an S6 which has different debug options.
                          -Rupp
                            Those errors seem to point to the intel display drivers. Even the Call Trace sections mention crt detect.
                            Do you have a crt plugged into the unit?
                            79 Z-Wave Nodes, 131 Events, 383 Devices
                            Z-Wave, UPB, WiFi
                            Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
                              Good Copy. Thanks.
                              i was searching and not paying attention to where i was.
