WD200 Can I turn off the side LED after reaching desired brightness?
  • WD200 Can I turn off the side LED after reaching desired brightness?
    I have just migrated a bunch of GE dimmer switches to WD200s. Is there a way to turn off the side LED after the dimmer has reached the desired brightness level? I find the always on light bar distracting. I played around with the Status Mode in the Zwave settings but it switched to status mode way too fast.
    The perfect scenario for me would be the normal effect of Status Mode disabled but the brightness light bar would turn off (instead of staying on) after a 4-5 seconds.
    Thanks.
    Couldn't you just enable status mode? I believe this turns the LED lights off unless using press and hold for dimming. The LED lights in status mode are off unless an event is created causing them to do something.
