HS-WD100+ Parameter for "100% Dim" instead of Last?
  • HS-WD100+ Parameter for "100% Dim" instead of Last?
    Is there as setting or work around to allow the dimmer to turn full on (100% Dim) regardless of what the Dim % was before it was turned off (rather than returning to the last dim value)?
    4
    Turn it on with a 99 value. An oddity of Z-Wave dimmer devices is that the highest "on" setting is actually 99 which can be a bit confusing.
      4
      Sorry I missed this on Saturday. I see you have the Easy Trigger plug-in. Here is an event that will do what you want.
      Any time you turn the light on (to any level) from Off, it will set the light to On. Then you can still locally control it, since the event only triggers when the light goes from Off to any value. Once the light is Off, the event will run the next time it is set to any dim level.
      Randy Prade
      Aurora, CO
      Prades.net
        Randy,
        Thanks for the help. Your even example using Easy Trigger is a perfect solution to my problem. Hopefully, my WAF will increase again,
        4
