HS-WS100 Issue -- On Off On Clicks
  • HS-WS100 Issue -- On Off On Clicks
    Recently, several of my HS-WS100 switches have begun, when manually switched on, click On, then immediately turn Off, then back On. Previously, when I initially obtained the switches I encountered this, and there was a firmware update that supposedly addressed this, so I applied it; however, the issue is back and is happening with multiple switches (and they are all at current firmware levels).
    Anybody??
      Factory reset the switch and reinclude it. If that does not work it could be a bad switch.
        I have one doing the same thing... I updated the firmware a while back but it didn't help. It varies with this on/off behaviour. Some days are worse than others. Other days, it may only turn off/on once..So I'm thinking I need to replace it too. I'd be happy to find a good used one as they're pretty expensive here in Canada.
