HomeSeer lighting is Here!
This is a sticky topic.
  • I haven't installed my WD100+ yet, but with my GE switches, I had to break off the metal tabs (designed for that) to get two to fit together. . .
    Originally posted by AutomatedJim View Post
    I purchased and installed 1 WD100+ to replace a Smarthome 2476D using X10. It is installed in a double gang box.
    As far as the switch is concerned, I like the look and physical feel when pressing the top and bottom, very solid. I am still using HS2, would this be the reason for limited to no programmable options, ie: ramp rate?
    The other issue I had, this is a deal breaker if true. As I stated, this is installed in double gang box. I replaced one switch, the other is also a Smarthome 2476D. Both switches would not fit in the box together.
    Anyone else having an issue with this? If two WD100+ switches double gang box or four in a quad, will they fit properly? No matter what I tried, put the Homeseer switch in first, the Smarthome switch in first, try to install both slowly at the same time, could not get both in. I had to put an old Leviton Decora switch in the Smarthome switch's place to get the Homeseer switch installed.
    Amy feedback on installing multiple switches would be appreciated.
    Other than the physical install issue, really like the switch.
    • Originally posted by AutomatedJim View Post
      Yep, I have one box on an exterior wall (metal box) that is slightly narrower then 2 HS switch bodies. I was forced to use a standard light switch for one of the lights in that box.
      The HS switches are dimensionally identical to the standard GE/Jasco ZW4001 type switches. ~43.77w x 70.65h x 35.80d (from heatsink to back)
      RJ_Make On YouTube
      • Z-Wave Settings?
        In my review I've notices the timer setting is fixed at 3? Is this a bug, or a feature?
        RJ_Make On YouTube
        • Originally posted by TechFan View Post
          When I installed the switch I broke off the fins on right for the center of switch. Unfortunately not the issue.
            Yes, you must break off the tabs. I installed dozens of these switches. Even with tabs broken off, it is tight fitting three together in a triple gang box, but it worked for me in several triple gang boxes. Double gang you have a bit more wiggle room.
            John
            • Originally posted by ServiceXp View Post
              Looks like you found a bug. I just tried setting that for the first time and see the same behavior, it changes back to 3 after you click the Set button. When you go to change it again it seems like it remembers what you tried to set it to last time, but the change does not appear to make it to the switch based on the obvserved local ramp rate. The step setting above it does let you change the overall ramp rate, observed ramp rate changes.
              • Originally posted by jhearty View Post
                John
                Well that will be fun replacing a bunch of X10 switches. Especially in quad boxes...... It looks like it would fit, just don't get why it would not fit with the Smarthome switch.
                  That does look to be a very small old style metal box. If that's dry wall you might find one of those "old work" plastic boxes they sell at Lowes and HD a quick problem solver. I have installed many of those to replace slightly smaller old boxes and I don't have a problem fitting 2 & 3 of this style switches in the respective 2 & 3 gang boxes.
                  cheeryfool
                  • I would also buy the extra deep boxes to leave room for the rats nest of wires you likely have in a 3 or 4 gang box, especially given these are quite deep switches. N
                    cheeryfool
                    • Originally posted by cheeryfool View Post
                      Yea, all my boxes are extra deep. Our house was more or less gutted 12 years ago after a fire.
                      Village code specifies metal boxes and conduit so no go on replacing with plastic. I could get away with it until we sell the house in the future.
                      I'm thinking the rounded corners of the mud ring are my issue. Anyone think it would be viable to take a metal file and file out the rounded corners?
                      • Originally posted by ferraf View Post
                        thanks, I'll wait a little while for the firmware update instead of uninstalling and going through all the shipping and time to get a new one....
                        Thanks, Fred
                        Originally posted by macrho View Post
                        I'm having the same issues, on/off/on on a few switches. I'd be happy to test the firmware instead of yanking them out of the wall
                        We have firmware to test. If you want to give it a whirl, send me an email (mark at homeseer.com)
                        Learn About HomeSeer
                        • This is fixed, try the latest release, if its not fixed there, the fix will be in the update.
                          • Originally posted by rjh View Post
                            Ok, so I am a newbie to all of this and this and this will be my first post, so if this is a stupid question I apologize. When you say "try the latest release", where can updates to the firmware to the switches be downloaded? I have installed 3 sets (HS-WD100+ with HS-WA100+) and love them. Of course needing power at the switch is a challenge in a 40 year old house, so it is taking a bit more work than expected to get everything installed. By the time I am done I will have re-wired most of the house.
                              Updated Z-Wave plugin from 3.0.1.76 to 3.0.1.77. Issue was the same after the .77 update. By "the fix will be in the update." do you mean one coming soon? Or beta? I saw a 3.0.1.80 in the Internal Test section but the disclaimer at the top made me stop.
                              John
                              Current Date/Time: 5/19/2016 7:34:05 PM
                              HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.280
                              Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 2 Days 22 Hours 16 Minutes 45 Seconds
                              IP Address: 192.168.0.32
                              Number of Devices: 195
                              Number of Events: 166
                              Available Threads: 399
                              Enabled Plug-Ins
                              3.0.0.68: HSTouch Server
                              3.0.5959.34353: UltraM1G3
                              3.0.0.50: weatherXML
                              3.0.1.77: Z-Wave
                                John
                                Enabled Plug-Ins
                                3.0.1.77: Z-Wave
                                The fix will be a firmware update for the switch. To install the update, you'll need Z-Wave plug-in .80 or higher. We are testing this now and expect to roll it out pretty quickly.
