HomeSeer lighting is Here!
This is a sticky topic.
  • #76
    I am curious, I have several of these (Dragon brand) and wonder if I could update the firmware to HS version instead? I would be willing to lose a switch just to find out.
    HS's are cheaper and with the additional aspects of instant reporting and double tap associations, I would prefer to just switch all my current switches over and continue expanding buying HS versions.
    As an aside...
    I need to bite the bullet and buy HS but I keep waiting for the Alexa API to be confirmed solid and working. Meanwhile I use my Smartthings box and all the wonderful cloud issues they have.
    • #77
      As an aside...
      That's an interesting thought and curious if the GE could do the same. I think as long as the core zwave chip is the same, at least in theory some of the functionality would work. I highly doubt it though if the chip isn't at least zwave plus type.
      • #78
        Got one of the bulbs and installed it yesterday. Network wide inclusion worked great via z-tool+ and a z-net. It's on a bedside lamp and replaced a module. So far it works great!
        Sent from my SCH-R970X using Tapatalk
        68 Z-Wave Nodes, 174 Events, 326 Devices
        • #79
          Adjust hi/low dim levels
          On the Cooper rf9540s, you could adjust the low and high dim levels to compensate for bulbs having different dim ranges. On the WD-100s, I have bulbs that are near full brighness but showing only 5 lights on the HS dimmer.
          It would be nice to be able to set a high and low dim value so that full brightness of the bulb shows all the lights on the switch and barely on would show only one light.
          • #80
            Mark,
            Any plans to make a switch to control a ceiling fan?
            High, medium and low settings
            I would be in for 6 of them if they existed
            Cheers,
            Bob
            • #81
              Switch to control light.. and ceiling fan separately?
              Sent from my Galaxy Note 3
              • #82
                Originally posted by Blade View Post
                Mark,
                GE makes one that works pretty well, I have a couple. Personally I would like a dimmer type vs just the 3 modes.
                • #83
                  Mark,
                  Looks like they has turned into a feature request thread!
                  The Cooper switch includes a nice trim feature to compensate for flickering in older LEDs. Fortunately, the newer bulbs aren't as prone to this. Of course, the Cooper switches are also $20 more and are not Z-Wave Plus!
                  No plans for a fan controller or split fan/light switch at this point.
                  Learn About HomeSeer
                  • #84
                    Originally posted by macromark View Post
                    At this point, "on" ramp rate is adjustable for local control only. We may be able to change this in a future firmware release.
                    I just want to add my vote for this feature also. Odd that it works at the switch and not through HS3.
                    Originally posted by rprade
                    • #85
                      Ramp rate control would be great. Glad to see the five-packs for sale in the store too! I've got a five-pack on the way and will buy more if these work out well.
                      HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
                      Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
                      Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
                      Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
                      • #86
                        what about writing a scrip that sends a set of incremental increases/decreases when the load is turned on/off through HS? should be able to mimic a ramp up/down effect.
                        • #87
                          Beginning the replacement of all my switches, had a nice box show up yesterday (wife may not be too pleased)
                          • #88
                            Wow I am sure HS loves you!! Maybe you will have some pull to help get the ramp issue fixed
                            • #89
                              WD100+
                              This a great switch and I plan to start to switch out to the 100's have two now.
                              Can you provide instructions (step by step) on how to create the two and three click events. I have tried and am missing something.
                              Again you hit a home run with this switch.......
                              • #90
                                First of all the switch will create 3 devices and they will look something like this:
                                So, just create an event where the central scene device value "is set to" (your choice or 2-presses, 3-presses or press & hold).
