HS-WD100+ Firmware Now Available
This is a sticky topic.
  • #61
    If you are on the latest Z-Wave beta then you are good.
    If you get errors updating:
    1: The switch might be too far, communications needs to be very good due to the amount of data transferred
    2: The switch controls the update, not HS, so the switch will try to slow down the transfer so it does not "clog" the Z-Wave channel. If it detects too much traffic, it will abort the transfer. If you have too many devices transmitting, you may need to power them off.
    #2 is rare, unless you a device flooding data. I suspect #1.
    The switch is about 10' from the znet, so I doubt that's it. How would I be able detect number 2? Turning off devices can be a bit tough
    Sent from my SM-G950U using Tapatalk
    • #62
      Turn on device logging on the Z-Wave plugin config page (click on the name of the plugin on the plugins page). That will log all received Z-Wave commands, see if something is reporting a lot.
      Does the error happen immediately after starting the update, or after it runs for a while? It will take about 3 minutes to do the update.
      • #63
        happens immediately. i looked at the logs after turning that on... didn't seem to be anything out of the ordinary, other than devices reporting status. here's a snippet. and below that is what it looks like if i try the firmware again:
        Dec-29 1:27:16 PM
        Z-Wave
        ApplicationCommandHandler from node 73 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V3 Frame(7)=3
        Dec-29 1:27:15 PM
        Z-Wave
        Wine Closet Z-Net: Sending to node 73 (UnSecured) CC=COMMAND_CLASS_SWITCH_MULTILEVEL_V3
        Dec-29 1:27:15 PM
        Z-Wave
        Polling device: Vent Controller
        Dec-29 1:27:14 PM
        Z-Wave
        Device: Light Living Room Power Set to 1.423 (W)
        Dec-29 1:27:14 PM
        Z-Wave
        Setting device Power to value 1.423
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level, Parent: Light Living Room LED Mirror, Child:Light Living Room Power
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level_Real called for Light Living Room Power, Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level_Real: Initial device is Light Living Room Power
        Dec-29 1:27:14 PM
        Z-Wave
        ApplicationCommandHandler from node 43 HANDLING: COMMAND_CLASS_SENSOR_MULTILEVEL_V7 Frame(7)=5
        Dec-29 1:27:14 PM
        Z-Wave
        Device: Light Living Room Watts Set to 1.423 (1.423 Watts)
        Dec-29 1:27:14 PM
        Z-Wave
        Setting device Watts to value 1.423
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level, Parent: Light Living Room LED Mirror, Child:Light Living Room Watts
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level_Real called for Light Living Room Watts, Type=COMMAND_CLASS_METER_V3, EndPoint=0
        Dec-29 1:27:14 PM
        Z-Wave
        Set_New_Level_Real: Initial device is Light Living Room Watts
        Dec-29 1:27:14 PM
        Z-Wave
        ApplicationCommandHandler from node 43 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
        Dec-29 1:27:08 PM
        Z-Wave
        Setting device Watts to value 0
        Dec-29 1:27:08 PM
        Z-Wave
        Set_New_Level, Parent: Light Master Bedroom Zooz Switch Binary, Child:Light Master Bedroom Watts
        Dec-29 1:27:08 PM
        Z-Wave
        Set_New_Level_Real called for Light Master Bedroom Watts, Type=COMMAND_CLASS_METER_V3, EndPoint=0
        Dec-29 1:27:08 PM
        Z-Wave
        Set_New_Level_Real: Initial device is Light Master Bedroom Watts
        Dec-29 1:27:08 PM
        Z-Wave
        ApplicationCommandHandler from node 34 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
        Dec-29 1:27:06 PM
        Z-Wave
        Dec-29 1:27:06 PM
        Z-Wave
        Dec-29 1:27:06 PM
        Z-Wave
        Dec-29 1:27:06 PM
        Z-Wave
        Dec-29 1:27:06 PM
        Z-Wave
        ApplicationCommandHandler from node 35 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
        Dec-29 1:27:05 PM
        Z-Wave
        Setting device Kitchen table to value 0
        Dec-29 1:27:05 PM
        Z-Wave
        Set_New_Level, Parent: (Nothing), Child:Light Kitchen Kitchen table
        Dec-29 1:27:05 PM
        Z-Wave
        Set_New_Level_Real called for Light Kitchen Kitchen table, Type=COMMAND_CLASS_SWITCH_MULTILEVEL_V3, EndPoint=0
        Dec-29 1:27:05 PM
        Z-Wave
        Set_New_Level_Real: Initial device is Light Kitchen Kitchen table
        Dec-29 1:27:05 PM
        Z-Wave
        ApplicationCommandHandler from node 60 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V3 Frame(7)=3
        Dec-29 1:27:05 PM
        Z-Wave
        Wine Closet Z-Net: Sending to node 60 (UnSecured) CC=COMMAND_CLASS_SWITCH_MULTILEVEL_V3
        Dec-29 1:27:05 PM
        Z-Wave
        Polling device: Kitchen table
        Dec-29 1:26:39 PM
        Z-Wave
        Dec-29 1:26:39 PM
        Z-Wave
        Dec-29 1:26:39 PM
        Z-Wave
        Dec-29 1:26:39 PM
        Z-Wave
        Dec-29 1:26:39 PM
        Z-Wave
        Dec-29 1:26:38 PM
        Z-Wave
        Setting device kW Hours to value 12.122
        Dec-29 1:26:38 PM
        Z-Wave
        Set_New_Level, Parent: Light Master Bedroom Zooz Switch Binary, Child:Light Master Bedroom kW Hours
        Dec-29 1:26:38 PM
        Z-Wave
        Set_New_Level_Real called for Light Master Bedroom kW Hours, Type=COMMAND_CLASS_METER_V3, EndPoint=0
        Dec-29 1:26:38 PM
        Z-Wave
        Set_New_Level_Real: Initial device is Light Master Bedroom kW Hours
        Dec-29 1:26:38 PM
        Z-Wave
        Dec-29 1:26:36 PM
        Z-Wave
        Dec-29 1:26:36 PM
        Z-Wave
        Dec-29 1:26:36 PM
        Z-Wave
        Dec-29 1:26:36 PM
        Z-Wave
        Dec-29 1:26:36 PM
        Z-Wave
        When i try the firmware...i get this over and over...
        Dec-29 1:32:57 PM
        Z-Wave
        ApplicationCommandHandler from node 93 HANDLING: COMMAND_CLASS_FIRMWARE_UPDATE_MD_V2 Frame(7)=5
        Dec-29 1:32:57 PM
        Z-Wave
        Wine Closet Z-Net: Sending to node 93 (UnSecured) CC=COMMAND_CLASS_FIRMWARE_UPDATE_MD_V2
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:57 PM
        Z-Wave
        Dec-29 1:32:56 PM
        Z-Wave
        Dec-29 1:32:56 PM
        Z-Wave
        Dec-29 1:32:56 PM
        Z-Wave
        • #64
          Someone said the .130 plugin worked better, so give that a try.
          • #65
            OK... that kinda worked.
            it took the firmware update. but now it's freaking out a bit.
            LED lights and paddle is backwards, even though it's set right in settings. And changing it back/forth seemed to fix that one.
            Seems to turn off and/or dim randomly on it's own as well. After a bit this stopped... maybe it was the rescan I did?
            Ramp rate locally was set to 32... which was really high.
            and response to remote zwave very slow... sometimes seemingly non existent. Or it just seems to blink/ramp/turn off and off randomly.
            thoughts?
            EDIT: a few airgap pulls and i was finally able to exclude/include. works now. thanks!!!
            • #66
              Can't update the firmware. Getting this error in log after about 45 min to 1 hr after selecting the file and clicking start:
              Error, FIRMWARE_UPDATE_MD_GET received that is requesting 0 reports. Can not continue, too confused.
              not seeing any type of counter like the readme txt file says.
              • #67
                I had an issue updating firmware and had better results with this.
                I used the Zflash utility and used the firmware in the library that comes with the utility. Then after it completed I did a rescan and the firmware then reported correctly.
                Stuart
                • #68
                  I have some BR40 LED bulbs that have never dimmed below +/- 30%. For giggles I went from FW5.19 to 5.14 and now I can dim to about 15%. I'm thrilled as it appears all other functions work just fine.
                  My question is if now I can go lower than before, why can't this dimmer be made to go to 1%? Is there a FW that might be able to make it go lower?
                  • #69
                    Ok... now I'm confused. I replaced my stairway light about a year ago and after reading this thread, I thought I'd check it's rev. it reports
                    Current Firmware: Manufacturer = HomeSeer Tech Version: 50.3.
                    I used the root device... this is correct isn't it?
                    What's the latest version of firmware?
                    Robert
                    • #70
                      I'm not sure of the latest firmware for these, but where did you get that version #? I seem to remember that depending on where you look, you may get a different version number.
                      I can find a number that matches their scheme on HS3 by going to PLUG-INS -> Z-Wave -> Node Information. The firmware version that HS references is circled in the picture below:
Name:	zwave firmware.png
                      • #71
                        Ok… this is what I see.
                        • #72
                          well you're obviously pulling from the same place... I'm out of ideas... hopefully someone smart may chime in
                          • #73
                            Well... looking back at my records, I ordered my replacement on June 25th of this year. So it's quite new.
                            • #74
                              To follow up, 50.3 seems to be what is shipping now... here is a link to one discussion on it:
                              https://forums.homeseer.com/forum/ho...witch-firmware
