Ok, this may seem strange but bear with me. I'd really like to see a flicker setting on the WD-200 dimmers. What you would have is a parameter would put the dimmer into flicker mode which would cause the light to flicker like a candle or lantern flame. The larger the value the faster the flicker so 0 would be quite slow and 16 would be much faster. There would also have to be a flicker range parameter so say if you set that to 50 the flicker range would be the dim value minus the range. So if one set the dim value to 100 the and the range parameter was set to 25 the dimmer would flicker the light between 75 and 100 sudo randomly.
Why would you want to do this? It's a great special effect one can use for front lights on a house, on your patio or even in the bedroom.
Personally I would not mind if this was a special firmware load that leaves out other less used features like the new remote switch function.
Anyway, it's just an idea but the meantime I'm looking for some flicker modules that might work with dimmers.
