WD200+ from dimmed to 100% on
    If my WD200+ switches are dimmed then turned off, I'd like a single tap up to turn it to 100% and not to the last dimmed setting.
    Is there a way to do this with settings on the switch?
    If not, I'm using HomeSeer 3. Can I do it from there?
    I use an event to do this. If central scene 1 is pressed, then the event sets the device to on.
      I use two scenes on my WD100+ . Single tap for the stairway light to 25% and double tap to 100%. Anyone visiting is happy enough with the chandelier light at 25% for going up the stairs at night - more than ample lighting.
        Oh boy, this is a good question. Was used to Insteon where they always went back to the "programmed" setting. Just starting with these z-wave switches and hope that this sort of a thing can be programmed. I'll play around with this in the coming days and report back.
          I have an event for each of my HS dimmers. I use 'had its value set to Scene 001 Key Pressed' which calls a script passing the device's id; the script either sets the light to a dimmed value or fully on depending on the time of day. If a light is already dimmed it sets it to 100%. Since I have my lights ramp up and down the script has no detectable delay.
          As Calligoo said; an event can accomplish what you're looking for.
          HS4 Pro on Shuttle NC10U, Win10; Z-NET
          Number of Devices: 1005
          Number of Events: 293
          Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
          External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
            Take a look at the post Randy made about dimmer default levels, I’ve been using these for awhile and they work great!
            https://forums.homeseer.com/forum/ho...evels?t=182447
            HS4 4.2.6.0 &HSTouch Designer 3.0.80
            Plugin's:
            weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
              Okay, with of the suggestions here I can get pretty close if I use just one switch. Now let me throw a wrinkle in the mix.
              I have two WD200+ switches updated with the .13 firmware. They are in Association Group 2 with each other, and linked with each other.
              This results in things getting pretty wonky. Here is an example log. The last dim level was 5%, and I tap on from the off position. Local and remote ramp rate are both 1 on both switches.
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Set to 99
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Slave Set to 99
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Set to 5
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Slave Set to 5
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Set to 5%
              Nov-06 21:14:42         Device Control Device: Upstairs Bedroom Lights to On (99)
              Nov-06 21:14:42         Event          Event Trigger "Light Control Bedroom Lights Full On"
              Nov-06 21:14:42         Z-Wave         Device: Upstairs Bedroom Lights Scene Set to 1000
              Any suggestions?
                As others have said, you can use a Central Scene Trigger. I use default values for different times of day/night for all of my dimmers.
                For your specific requirement, the Easy Trigger plug-in will do exactly what you ask.
                Click image for larger version  Name:	69D8E95F-F675-4216-B72B-1EE6A9C1B1B2.jpeg Views:	1 Size:	27.6 KB ID:	1257664
                  I do have an event trigger on the central scene: "Light Control Bedroom Lights Full On". However, it is different than yours.
                  I'm playing around a little bit with a trigger now that looks more like yours but haven't finished yet.
Name:	Screen Shot 2018-11-07 at 3.09.35 AM.png
