Set all HS-WD200 to normal mode
    I have an event that will update all the dimmers to status mode and display a single blinking led. That works fine. The problem is I cant seem to return all the devices back to normal mode. Am I doing it wrong, or is there another way?
    You should be doing this in a two step process.
    1. Set the switch into "status" mode or into "normal" mode
    2. Set the color of the LED and /or flashing
    In your event you only set the normal color. You will also have to set the switch to "normal" mode.
      Hmmm...looks like you have different options then I do. Maybe I need an update. Will check software/firmware version this afternoon
        Looks like I have the newest (stable) software:
        Current Firmware: Manufacturer = HomeSeer Tech Version: 5.11 (WD-200)
        HomeSeer Version: HS3 Pro Edition 3.0.0.500 (Windows)
        John: Are you running any beta releases ?
        Update: Looks like 5.14 is the stable release now. Starting the slow process of updating. Will report back after.
          I am running 5.11 firmware on the dimmer and HS3 Pro 3.0.0.511 on windows
          also running 3.0.1.252 for the z-wave plugin - I think this may be your issue
Name:	Screen Shot 2019-04-09 at 11.37.53 AM.jpg
ID:	1297998Click image for larger version
Name:	Screen Shot 2019-04-09 at 11.37.35 AM.jpg
            here are the options I get in the event setup
              Yep...that was it...had to update the z-wave plugin.
