Hi guys, is there easy way to set value of last to 100%?
It turns out most people will try to turn lights off by holding switch down dimming it to minimum level not realizing that they are just dimming down and not turning it OFF.
Basically I would like to on some level reset the switch to when next person comes in and turn the light on it will go to 100% and not to 2% last person set it to. I would re-set the switch as needed with event.
1. I found out that I can use event to turn light ON and OFF using event. That will do the trick but not ideal at all.
2. I think I will set Low Dimming Threshold to something like 15% so people will get the hint that they are not turning the light OFF
But my me question stands. Is there any parameter to set Last to 100% without turning light ON and OFF?
Thanks for your advice. Charles
