Using the Multitap feature of the Wd-200+
    Hi All,
    I am trying to trigger an event when my switch is tapped X times. I am using a "The Device had its value set to..." trigger but I am not sure what to select as the value.
    In the examples I have seen in the documentation for this dimmer, there should be "Scene 01 Key Pressed 3 times" or something to that effect. I don't have that option. Any Ideas?
    Thanks.
    It is likely the device was not properly scanned when including it originally. Try a rescan of the root (under the Z-Wave tab) and see if the Status/Graphics of the Scene child is built with all of the correct entries. It should work, if it doesn't delete the scene child and try rescanning again.
    The Scene child should look like this
      That did the trick. Thanks Very much for your help.
