I'm still learning about setting the LED colors. I followed the instructions on the video in the help section but it didn't work for me. I created an event when the paddle is pressed 3 times the status colors change to red. Nothing happens. But playing around with it I found that when I first changed the mode to status and then changed the color all worked. In the video it didn't seem like you had to do that first step.
New HS-WD200+ Status LEDs Question
Guest
Originally posted by joewilly1 View PostI'm still learning about setting the LED colors. I followed the instructions on the video in the help section but it didn't work for me. I created an event when the paddle is pressed 3 times the status colors change to red. Nothing happens. But playing around with it I found that when I first changed the mode to status and then changed the color all worked. In the video it didn't seem like you had to do that first step.
Do note that the ZWave event action (HS-WX200 Actions) need to be set to "Set Status Mode LED color" as opposed to "Set Normal Mode Color".
Could you include a screen shot of the event changing the status color?
