A few month ago, when I switched to the Edge driver, my WD200+ started acting flaky. Every once in a while it would enter what I now know to be Smart Bulb mode. I would use the air gap switch to reset to normal mode. I figured that, after so many years of great service, the switch was on its last legs and replaced it with a WX-300. Same problem. So I took a look at the Edge driver. The driver does not have setting for the newer functions: smart bulb, paddle toggle, default dim level and LED brightness. I am wondering if the values for those settings are not being initialized to anything in particular, and every once in a while a non-zero value is sent to the switch for the smart bulb parameter. I haven't noticed any of the other new functions being affected, so I may be off base. Is anyone else seeing this problem?
Also, is there a toggle sequence to get out of smart bulb mode? 3X up/1X down puts it into smart bulb mode, but doesn't take it out again.
