Setting the dimming level on the HS-WD200+ to "Last" is ignored, the light stays on the current brightness, not the previous brightness. All other dimming levels work. Is there a special procedure to tp program the dimming level to "Last" in order to revert to the previous light level?
Setting dimming level to "Last" has no effect on HS-WD200+ Wall Dimmer.
Hi Wade, Thank you for your reply. I have an event which turns on a HS-WD200+ wall switch to 17% at dusk and off at 9:00 pm. During this time period or later a motion detector event will turn the switch to 100%. Fifteen minutes later I want the switch to return to 17% (or off, if that was the condition when the motion detector activated.) I tried to use the "last" setting to accomplish this. Apparently the "last" setting does not work in this manner. Do you agree?
Paul
Originally posted by rougemont603 View PostHi Wade, Thank you for your reply. I have an event which turns on a HS-WD200+ wall switch to 17% at dusk and off at 9:00 pm. During this time period or later a motion detector event will turn the switch to 100%. Fifteen minutes later I want the switch to return to 17% (or off, if that was the condition when the motion detector activated.) I tried to use the "last" setting to accomplish this. Apparently the "last" setting does not work in this manner. Do you agree?
Paul-Wade
- Likes 1
