HS-WD200+ commands fail
    I am having a very inconsistent results with the Z-Wave commands with 200+ devices. I have an event that sets a specific LED to a color and blink. Very frequently, only some of the devices work.
    Here is some log output from a single event running.
    Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 31 Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 18 Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 6
    Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 4
    Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 37
    Legacy-Plugin Z-Wave Error Event Action Set HSWX200 action for event ... failed for device node 30
    Only about 15 of the 38 nodes on this network are these switches, so this means a third of them are failing to update. They are all new switches (August or newer), so I believe they all have the latest firmware.
    I have run full optimize a number of times. Any ideas of what the issue is?
    New fresh install of HS4 as of about a month ago.
    funny I was just reading a post about zwave network slowdowns/trouble. Try this and see if it helps
    https://forums.homeseer.com/forum/ho...e-optimization
    HS4 Pro on Shuttle NC10U, Win10; Z-NET
    Number of Devices: 1005
    Number of Events: 293
    Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
    External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
      "... any events addressing multiple lights would run SUPER SLOW and throw lots of errors ("Failed Sending Z-Wave Command to Device"). I have asked HomeSeer about it and they say that you cannot address more than three lights at a time without programming in a delay. ..."
      Citation.
      HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
      Home Assistant 2024.3
      Operating System: Microsoft Windows 11 Pro - Desktop
      Z-Wave Devices via two Z-Net G3s
      Zigbee Devices via RaspBee on RPi 3b+
      WiFi Devices via Internal Router.
      Enabled Plug-Ins
      AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
