I'm looking for a 20 amp z-wave switch for a pool light, which I believe is a 400 watt incandescent. Almost all switches I find a 15 am. Ideas on where to find this?
20 Amp Z-Wave Switch
Originally posted by drhtmal View PostGE makes one. Do a search on GE heavy duty switch.
Eman.
- Likes 1
Originally posted by joe@kirbyperformance.com View PostI'm looking for a 20 amp z-wave switch for a pool light, which I believe is a 400 watt incandescent. Almost all switches I find a 15 am. Ideas on where to find this?
HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by joe@kirbyperformance.com View PostIt is a 20 amp service. I’ve tried two different 15 amp switches, neither of which worked.
Also, if you look at the old toggle switch that was in the jbox you will see that it is also rated at 15 amps.
This is not related to your problem, but most people don't realize that the circuit breaker is there to protect the wiring in the wall. The breaker is not there to protect the load.
Originally posted by TC1 View Post
The service rating of the branch circuit (20 amps as you claim) has nothing to do with the current draw of the actual load. When you say 15-amp rated switches don't work, did they fail? Not turn on at all? If they failed then you have something more than just one 400-watt lamp on that circuit which you really should determine what the true nature of the load is.
The switch only powers a single pool light, which the installed stated was 400 watts; no other service from this switch.
Please state *what* fails. Did the circuit breaker trip? Did the switch fry and become non-responsive?
All that being said, there is no reason a 15-amp switch wouldn't work. As others have asked, define "neither of which worked". Do the wires not fit the switch terminals, does the switch not work, etc.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Please state specifically *which* Z-wave switch model you installed that did not work. As stated previously in this thread, a 400-watt incandescent lamp is under 4 amps in terms of load and is also non-inductive (which means there should be no surge current when initially turned on).
The switch would not power the light on or off. I then tried a Eaton 15 amp Z-Wave. Same issue. Reinstalled 20 amp dumb switch and it works fine.
Enbrighten Z-Wave Smart Toggle Light Switch with QuickFit and SimpleWire, 3-Way Ready, Works with Alexa, Google Assistant, ZWave Hub Required, Repeater/Range Extender, White & Light Almond, 46202
- Likes 1
You need to confirm that the white wire is a neutral. If it is, a neutral will most likely be required for any smart switch. Likely the line is black and the load is red. You would also need to confirm that. Smart switches require line and neutral to function. Then they can switch the load on and off. The green is ground.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
- Likes 1
