HS-CAM-I reset button
    For the life of me I cannot find the reset button on the cam to add it to my app.. if someone has a pic or diagram or something.. I must be getting old
      https://youtu.be/n-ChybxDRcc at about 1:45 in this video they talk about the reset button.
      https://homeseer.com/guides/HS-CAM-I-Manual-3.pdf
      Manually tilt the lens of the HS-CAM-I so that it is looking up to the ceiling to expose the RESET button next to SD card slot). Press and hold this button for 5 seconds until the blue LED below the lens starts to blink slowly. If the blue LED does not activate, try using a solid object like a flat-head screwdriver to gently hold down the button. Advancing to the next screen will create a QR code which the HS-CAM-I will read and use to connect to Wi-Fi.
        thanks.. JFC this is the world's smallest reset button, so small it's hard to tell if it's pressed.
