Hi everyone,
I apologize in advance if this is already asked, but I do not see it in the forums.
does anyone have a recommendation for external full PTZ PoE camera that is compatible with HomeSeer? I need to mount 2 units approximately 35 feet up to the bottom of an 15 degree angled soffit (so need adjustable base to level camera from the angle) , I do not want to screw this up due to the lack of accessibility one the cameras are mounted.
I have PoE ran to the area and will be running HS Pro on a designated server and need for my client to be able to access the images, and control the cameras from inside HS if possible, long with image tracking, day and IR, plus fixed disk recording.
is it recommended to install cameras along with blue Iris? Forgive the questions, but I am new to cameras but not new to HS.
What camera do you use, what software, and what plugin?
thanks in advance.
gary
thanks in advance.
gary
