I'm trying to change parameter 2 of the FloodLight Sensor motion sensor to ignore the dial switch on the back of the unit and instead setup an event to turn the light ON based on PIR motion.
below it is the configuration setting. that I have questions about
Lux sensor threshold: Lux level to activate the PIR. When the lux level falls below this threshold and the PIR gets triggered, the unit emits a Basic Set Command (Value=0xFF) and turns on its floodlight. This overwrites the Lux level set by the Lux knob.
Parameter Size Range Default
2 2 0,30~200, Factory default at 50
255 Setting = 0: always don’t turn ON light
Setting = 30~200: lighting activation by setting
Setting = 255: turn ON light upon PIR triggered
If the level is set to 0, the unit will not turn on its floodlight. The PIR will still send a notification report to the controller; if the level is set to 255, when motion is sensed, the sensor ignore the ambient brightness but just turn on the light.
I have two questions
1 what does the Setting =30-255 actually do ? what does 30 mean or what is 255 with respect to the flood light function I don't understand the range. how does this relate to the physical dial switches?
2. What setting is appropriate to stop the PIR from directly turning on the light . Instead I want the PIR motion to trigger an event in HS4, the Event will "Switch" ON the light
Devoir
Devoir
