And I found cycling Power reloads the parameters if they have been changed. Very odd behavior
FLS-100 constant motion
Well no luck ... one is unreliable and constantly finds motion. The other is more reliable but is impossible to point and trigger consistently. What is the best independent z-wave motion sensor out there? I can mount one (line powered) on my steps pointing directly down the driveway and then use it to trigger the lights directly and ignore the PIR sensors. And I found out that the super expensive 007 lights use the same base HS units...
If you can find a used Gen 1 HS-FLS100+, we've had zero issues with constant motion on the original sensor and have replaced a couple G2 units with the original as a short-term solution, since a firmware fix doesn't appear to be in the cards. Long-term, Zooz is coming out with an outdoor 700/800 series LR sensor in late summer that's worth a look.
