Is it possible to turn off Temperature reporting without changing the Luminance Reporting? I'm using the Luminance reporting, but don't need the temperature and would like to turn it off.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
