Recently purchased a motion MS100+ Motion detector. I am running off batteries, and configured that way initially with the Ztool+ phone app. Have a Zee Troller S2 if that matters.
I have an ON event which it is correctly triggering with the MS100 'Motion Detected', don't see any problems there.
I have an OFF event that is triggered with MS100 'No Event', and this appears to be working okay as well.
I cannot figure out how to get access to the advanced configuration parameters indicated on this:
https://cdn.shopify.com/s/files/1/12...S-MS100v1b.pdf
Not visible on the root, or any of the three HS3 created devices for that matter.
I have pressed the MS100 network button 4 times, and HS3 communicates after I do that, I can see it on the device Zwave tab.
I am not getting a battery status or root status (installed yesterday afternoon), and can't tell if MS100 is defaulted to disable that, or what any of the parameters are because I can't get into the advanced configuration parameters. What is wrong, or what is the trick?
I've been reading thru previous forum entries, but haven't found anything on this yet.
