I'm trying to associate this motion sensor with a light that is about 8 feet from it and I can't get it to work. Are there any hidden parameters that I don't know about? What settings should be applied to the motion sensor? This is driving me nuts. Any help would be appreciated.
Association with light
Originally posted by simplextech View PostHave you contacted support with your question? A lot of people don't use device associations so maybe they haven't tried and maybe this sensor doesn't support it. I don't know but you should contact support to find out for sure.
Originally posted by jayman13 View Post
I guess I will. I'm surprise more people don't associate a motion sensor with a light if that is true. It's much quicker and reliable in my opinion. Thanks.
I setup a motion device
I setup a light device
I setup an event.. if motion then light on
interesting - never thought of using an association.. well I have never used an association, or scene... so something for me to dive into someday...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by Tomgru View PostIf I understand correctly, they work even if HS is down....useful for a very simple case. For example, when I open my pantry door the light comes on...goes off if I close it. No need for two separate events or HS3 to manage that with an association.
Originally posted by Tomgru View PostIf I understand correctly, they work even if HS is down....useful for a very simple case. For example, when I open my pantry door the light comes on...goes off if I close it. No need for two separate events or HS3 to manage that with an association.HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
