Need Examples of Setting Up This Sensor
    #16
    I'm using HS4 and I don't see anything that says Home Security on the features of the device. Maybe I will try deleting and reinstalling the sensor...
      #17
      Take a look at parameter 18. The default time for going back to No Motion is 600 seconds. You could set that to 30, then select 2 bytes, and wake it up and then push Set. Make sure it comes back with that same value you entered before selecting Done. Waking it up requires 3 quick presses of the button.
      Here is user guide.
      https://homeseer.com/wp-content/uplo...HS-MS100v2.pdf
        #18
        Thanks for your suggestion. I finally removed the node and reinstalled (it took 3 attempts before it would create properly) and then everything works fine.!
