Is there a way to get the lux number instead of percentage? The lux level is very large, which is good, but that means the percentage resolution is very crude. If you are dealing with lower light levels 1% difference makes a big difference. I just purchased a bunch of those HSM200 sensors but they are kind of useless with the low resolution they provide. Either they should report lux level or they should report 1 decimal point for the percentage number.
Getting Lux Instead of Percentage
Originally posted by wlh2 View PostIf I remember correctly, I had to set a polling interval in zwave settings in order to get them to show as lux.
https://forums.homeseer.com/forum/ho...33#post1288033
If you have the newer HSM200s with the screw tab, you will need to update to the latest firmware in order to disable automatic reporting.
https://forums.homeseer.com/forum/ho...86#post1429186
HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
