HomeTroller Zee WiFi Adapter Now Available
    An optional WiFi adapter is now available for the HomeTroller Zee.
    Store link: http://store.homeseer.com/store/x-P1669C102.aspx
    The adapter does come with a driver CD and will run on XP or higher versions of Windows too.
    Learn About HomeSeer
    Mark,
    How do you install it on the Zee.
    I just plugged one in (realtek chipset).
    I then plugged it in rebooted and configured it to have a static IP address along with primary ethernet port and locked myself out of the zee.
    The Zee did see the little WLAN USB device right away.
    Do I have to unplug the ethernet cable to use the wireless stick?
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
      I got the wifi adapter with my HT-ZEE & it had no instructions but plugging it in to the HomeTroller and with hard wired Ethernet to configure it worked fine... find.homeseer.com then log in tools -> setup -> network -> wifi settings & type in SSID, select security & pass phrase then tools system restart & pull the Ethernet plug out. Give it time to reboot then do find.homeseer.com again to find it using wifi... The blue light on wifi adapter will glow with traffic when working, see pic. Highly recommend Homeseer consider automating steps to save customers some time... Making a video & updating instructions...
      Cheers!
      The adaptor will glow blue with activity when working
        The lights on the zee unit itself, what do you have blinking. I only have the top light. I have worked on this all day and no luck. When I do the search I find it, but the web page will not show.
        danielbo
