Access to Zee in a SSH (Putty) session
    Is it possible to connect to the Zee in a SSH or telnet session directly ?
    I thought I read this somewhere but can't find the thread now.
    Yes - you can use PuTTY to connect with SSH (port 22).
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      SSH to Zee
      Ok maybe a few hints
      Like what username did you use (I tried root (or su) with the password I supplied at startup
      No Luck
      Yes I know the ip address to the Zee and I did get a login prompt
      Any other suggestions
        Thinking I used Homeseer or Admin with the Homeseer password.
        I then changed the root password and now use root. I changed it while sshing to the Zee.
        I think too when you connect an HDMI monitor it defaults auto logging in (don't remember).
        I just went to the Zee and to the Linux tools section. I typed "whoami" and it said I was root.
        Have you changed the password there to something else?
        - Pete
        Auto mator
        Fanless IntelĀ® Celeron N3160 SoC 8Gb
          A Zee out of the box will have a user of homeseer and a password of hsthsths3.
          You should change this password as well as your root password.
          You are prompted to change the password when you first access the Zee over http.
          Z-Wave, UPB, WiFi
            Good Stuff
            Thanks for all the info
            I'll give a try later tonight
              Logging into the Zee via SSH
              So the username was homeseer and the password was what I set at initialization
              Thanks for the help
