Hometroller ZEE and Door Switches
    I have a Zee network that I need to add door switches to. I have two Schlage PS516-485 that I bought on homeseer.com. I can sucessfully add these to the network but when the Zee detects a state change in the switch I get the following error in the log.
    Node Change Event for Node 3 on Network XXXXXXX, CC=COMMAND_CLASS_NOTIFICATION_V4 but no valid devices were found.
    Is their a solution for this? I need these two switches to work correctly so that I can monitor my front door and my driveway alarm.
    Try a rescan on the root device.
    Sent from my SCH-R970X using Tapatalk
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      Solved
      It was my fault. Everything works correctly with the cover on the switch. I think the switch was in tamper mode. Thanks for the suggestion.
