Remote Desktop for Zee
    Any suggestions or ideas for using a remote desktop application with the ZEE. I am a little worried about performance.
    I have used a couple before but not on a Zee.
    Maybe Krdc, RealVNC or Remmina
    Thanks for any suggestions !
    What is it you want to see?
    I utilize ssh and the web gui as my only interface to the Zee.
    I have connected the HDMI port to a monitor and utilized the command line prompt; that is all I did though on the Zee.
    - Pete
    Auto mator
      Remote Desktop
      Just a desktop instead of the terminal like interface.
      Some of the Linux tools are easier to use with a desktop.(Installing apps, monitoring updating)
      Not that I haven't been able to get 90% of the what needs done thru SSH (putty) and Webgui
      Just wanting to try using the Zee as a desktop to play a game, maybe run an app (Linux Touch client) install things like possibly Media Server or a IR Controller.
      The big concern is the performance !
        For those of you wanting to access the desktop, I added a thread about how to do this here:
        http://forums.homeseer.com/showthread.php?t=163612
        You can install VNC using apt-get and then access the desktop remotely.
          VNC for ZEE
          Thanks Rich !!!
            Another tool you can utilize in wintel for remote desktop is called xming.
            http://sourceforge.net/projects/xming/
            You can run and see the entire desktop or just one application with xming.
            - Pete
            Auto mator
              Thanks Pete
              I will giving this at try this week end.
              Pete any idea of this tools impact on performance. As Rich mentions they do NOT recommend running the remote desktop stuff full time .
              Is this your experience as well ?
              Thanks for all the feedback
                Yup; running a desktop and VNC will hit performance a bit.
                I am used to using VNC on the HS2 boxes remotely or using the KVM Java applet to get to them. They sit on a shelf and are mostly accessed remotely.
                Relating to windows access to the Zee I mostly just SSH to the device and utilize WinSCP and XMing to play a bit with.
                I have been goofing around with shutting down the Zee and running a Homeseer remote plugin from the Zee to HS3 Pro on Wintel or Linux and it works just fine.
                So I only use XMing when I want to see something in GUI mode desktop or single application; then shut it off.
                Goofing a bit I shut down Homeseer on the Zee and ran Homeseer touch using the XMing interface just to see it work.
                I have added the Webmin interface to keep an eye on the metrics and running Webmin will ding the performance as well; but that is always running on the Zee; it is a bit lighter than running the gui though.
                - Pete
                Auto mator
